Englander Igniter not getting hot at tip. Would you replace it?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Nov 15, 2015.
  1. don2222
    don2222
    Salem NH
    Hello
    25-pdvc
    Mfd = 08/08
    Stove is hard starting but runs fine.
    Replace Igniter? Oui? Non?
    See pics
  2. CleanFire
    CleanFire
    Oui - that igniter doesn't owe the stove anything..
    Have a 25-PDVC sitting in the workshop, has a bad igniter, co-worker has (2) 25-PDV stoves, both have bad igniters.. Seems to be a common failure part.
  3. don2222
    don2222
    Salem NH
    Hello
    Still taking 12-15 mins to fire up. I checked the air hole in the bottom of the igniter tube and it was clear. I also removed the drill cap on top of the igniter tube for more air flow.
    Then I pulled the burn pot and hammered out the top ridge so it was flat. The original OEM burn pot gasket was mostly desintergrated so I cut a new one.
    Also made sure the igniter tip was centered in the igniter tube and pulled back a bit.
    See pics
    Then I found the lower 3 buttons were set for 4-4-4 ! ! ! So I changed them to 4-6-1 and shut the stove down.
    Now we will see how long it takes to fire.
  4. CleanFire
    CleanFire
    Cool - nice work there Don. :yes:
    Interested to read if the gasket, igniter mod, and settings change fixed it ..
    If you don't mind me asking: what type / brand of gasket material did you cut / use for the burn pot?
    Thanks,
    Cleanfire
  5. don2222
    don2222
    Salem NH
    Hello
    After changing the 3 buttons to 4-6-1 the stove went from pressing the ON button to a FLAME in 6 Minutes flat! ! !
    For the Burn pot gasket, I use 1/8" white Lytherm good for 1,000 degs. Same as OEM but stays together a little better. :)
  6. CleanFire
    CleanFire
    Well that's spiffy, and fast!
    So you just left this piece off then?
  7. don2222
    don2222
    Salem NH
    Yes I did.
    So if the bottom hole gets blocked, it will still work.
  8. CleanFire
    CleanFire
    Gotchya.
    Don, you sell the gasket material used to make the burn pot gasket, correct?
    Edit: I'll PM you.
  9. don2222
    don2222
    Salem NH
    Correct
    CleanFire likes this.
