Wood insulation for your walls.
Discussion in 'The DIY Room' started by schlot, Nov 12, 2015.
  1. schlot
    schlot
    NW Iowa
    During some remodeling I ran across this sealed (enclosed) batt insulation in the walls.
    If you haven't run into it its called Balsam Wool. It was used predominantly during the 40s and was made in Cloquet Minnesota (west of Duluth).
    It was a insulation made from scrap wood bark and other by products that was sprayed with a fire retardant.
    Here is the inside of the insulation.
    When the kraft paper is cut the insulation falls out.
    It has a whopping R value between 1 and 2!
  2. papadave
    We have something like that in the main part of the attic, and it's got paper/vapor barrier on both sides.
    Still can't figure that out. Doesn't much matter, as it's falling apart.
  3. schlot
    schlot
    NW Iowa
    If it's anything like this, it needs to be sealed as the insulation is too loose to stand by itself.
    Well Seasoned and wildwest like this.
  4. papadave
    Just noticed that yours has the paper on both sides.
    I'll have to get a pic tomorrow.
    Well Seasoned, wildwest and schlot like this.
  5. schlot
    schlot
    NW Iowa
    A little more up to date insulation is in place now. :)
    Eric VW, Woodwidow, bogieb and 8 others like this.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Mice would have really enjoyed that soft fiber.
    My buddy had a compressed paper wallboard called "beaver board" on some of his walls.
  7. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Did you try lighting it to see if it would burn?
    Gary
  8. schlot
    schlot
    NW Iowa
    No, but I will give it a FHC test burn!
  9. cgraham1
    cgraham1
    Nor Cal
    In my house, some of the walls were filled with wadded up newspaper.
  10. schlot
    schlot
    NW Iowa
    Amazing...back in the days of cheap heating fuel.
  11. bogieb
    Mine had 1" thick rock wool. Approximate R value of a LOT less than needed :D. The sheetrock was 1/4" instead of 1/2" and there was no vapor barrier so the only thing stopping any wind was paint (many, many, many layers of that). Then of course there was that 8" of open space direct to the eaves of the house - the outside plywood just stopped there. My roof overhangs all 4 sides of the house, so there was a lot of sheetrock torn out, rockwool pulled out, plywood scabbed in, R-13 installed, and vapor barrier before putting up new sheetrock. Still have the kitchen to do, but it is the smallest room in the house, besides the bathroom, so that room is going to be waiting a while.
    Oh, and one wall had a 1960's Miller can in it for added R-value - empty of course.
    Brad38, Eric VW, schlot and 4 others like this.
  12. dusky
    dusky
    Pittsburgh
    That crap is what is in the crawl spaces on my third floor. It is on the "someday" list of things to deal with.
    wildwest, schlot, Eric VW and 2 others like this.
  13. Eric VW
    My dad always called "beaver board" what was used as lathe strips went out of fashion regarding plastered walls. Small, pre-sheet rock panels.... We have it in our house... Mite have just been regional name given to it on LI in the 50's-60's before sheet rock replaced plaster at large... I dunno.
  14. chris
    those must have been really cheap walls as the plaster and lath i am familiar with was at min. 1/4"x1.5 wood strips some were 1/2" apx, all rough sawed with octagonal chicken wire over that - several coats of rock hard plaster in/on that before a final top coat. tough walls and a real b.... to repair if the owner wanted period correct or was required for historical purposes ( note never buy a place on the or being considered for the Historical record/society ect)
  15. schlot
    schlot
    NW Iowa
    This house has the plaster with wire construction on the main floor.
    Those sheet drywall panels with plaster on the 1st floor kitchen addition and 3/8" sheetrock on the 2nd story addition.
    Insulation varies from nothing, to the balsam wool I show above to some (not much) standard fiberglass batts.
    It's like Christmas everytime I open up a wall. There is a surprise inside each one! :)
  16. papadave
    Our house downstate was built in '54, and when I redid the bathroom, I found expanded metal "lath".
    That was fun.
    schlot and Eric VW like this.
  17. Eric VW
    I've messed with proper plaster walls- mostly tear out/demolition- but our walls and ceilings have very few cracks... Plaster thickness is on average 1/2".....
    Still no fun to mess with here.
    schlot likes this.
