-3°, Stove cranked all night°°°
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Nov 15, 2015.
  1. bogydave
    House 71° this AM
    Full laod, just over 12 hour burn so far
    Will need to burn down the coals soon, they're building up
    need the space for wood, to be -8° tonight
    Forecast to get up to 4°, whoot............ whoot !
    gmule, lknchoppers, swags and 15 others like this.
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    Nice and comfy inside ehhh..do you shut the air down completely to get your 12 hours burns? Or do you leave it open just a bit
  3. bogydave
    On med High, 2.5, fan on med High
    If I shut the air off, 40+ hour burns, use that for 40° night time settings
    Shoulder season.
  4. Well Seasoned
    Mild fall, now Alaska showing her muscle! The blaze king will answer the call! Stay warm!:shiver::coldfire:
    Sean, Flatlander Pete, HDRock and 3 others like this.
  5. Todd 2
    Todd 2
    Where is 2.5 on your dial Dave ? I think about 3:00 is med high on mine. She will cruise just a little over a 500 deg surface temp set there. I was more than impressed with the high winds we had over the past couple days, not one hiccup and held the temp perfect where ever you set it.
  6. jatoxico
    jatoxico
    Long Island, NY
    This normal BD or unseasonably cold? Been warm on this side and not too many fires yet this year.
    Well Seasoned likes this.
  7. bogydave
    4:30
  8. bogydave
    has done this before,
    but it's 15 to 20 degree below "the norm"
    Late Dec thru Jan. is our below zero time.
  9. MightyWhitey
    MightyWhitey
    Cold in Alaska.............warm in the 48. Twas a high of 61*F here just South of the cheddar curtain.
  10. bogydave
    Up to 9°, a heat wave :D
    Chvymn99 and HDRock like this.
  11. bogydave
    papadave and Todd 2 like this.
  12. yooperdave
    Burn safe up there brother Bogy! You've been waiting for this.
  13. Backwoods Savage
    Don't let that outdoor heat wave get to you Dave. Take a bike ride.
    Oldhippie, NYCountry and Woody Stover like this.
  14. bogydave
    -11, house dropped below 70
    Wife was up early, added wood with a lot of hot coals before heating the chimney,
    low draft flow, smoked the house pretty good when the dry birch hit the hot coals.
    Vented the house, turned the furnace on to get house to 74
    Learning experience, get a good draft going before adding wood to a hot stove.
    Add wood fast
    Stove cranking now, should maintain 70s,
    6 mph wind now, -9, wind chill. -17
    papadave, Chvymn99, HDRock and 3 others like this.
  15. MightyWhitey
    MightyWhitey
    So did you "knock" some sense into her after that FUBAR??!! Or did you make her stand naked in the back yard??!!!
  16. HDRock
    What do you do to get the pipe hot beforehand?
  17. bogydave
    A cat stove doesnt' keep the chimney real hot, you need to warm it up a bit to get a good draft established.
    With all the hot coals in there,
    Open the bypass, stat to wide open, wait a minute,
    then crack the door for a couple minutes ,
    that gets a lot more hot gasses going up the flu & you get a good draft established.
    Then lay the wood you want to add right beside you
    you need to load all the wood in fast before the bark catches on fire
    Open the door, load fast & close the door.
    By the time I got down there from smelling the smoke , all was OK & the stove was up & running fine.
    She didn't have enough wood to fill the stove , so left the door open while getting more wood, the bark ignited
    & smoke rolled out the door. Not visibly real bad but enough we had to vent out the acrid smell, birch bark smoke smells real strong
    Just took too long to get the stove filled with the weak draft..
    Hopefully we don't have many more of the -11° temps to deal with.
    Already down to -4° right now though :(
  18. HDRock
    Oh, I see
    Really warm here for this time of year 63 today low 50 tonight, Thursday is going to start getting colder.
    I have been known to pre-stack, arrange, my wood before I go putting it on hot coals.
    I have a place marked out beside the stove, so I can arrange the pieces so they will fit real nice and tight,, so once I open the stove I can get it packed in there pretty good, pretty quick
  19. bogydave
    -5°
    Wife's load got the house to hit 74° :yes:
    Been burning down coals since noon, were lots .
    The house stayed above 72° all day :)
    Tomorrow the last day of the year for over 7 hour of daylight :(
    7:02
    Headed down to load for the night.
    HDRock likes this.
  20. Backwoods Savage
    Makes me shiver Dave.
