How I check to see if a tree is hollow
Discussion in 'The Wood Pile' started by CoreyB, Nov 10, 2015.
Tags:
  1. CoreyB
    CoreyB
    South east iowa
    This is how I was shown how to see if and how hollow a tree is.
    I do not know if this is the best way or if it is even safe.
    I know you can use a hammer but I am not as reliable that way.
    What are your thoughts? Do you know a better way?
    HDRock, haveissues, Norky and 3 others like this.
  2. bogydave
    I like it :)
    When in doubt, that's a good way to check. :yes:
    Watch for a change of color of the chips too, could be punky ( birch chips got from white to brown if punky in the middle)
    Sound & RPM change of the saw is another thing to pay attention to.
    What I've noticed in Alaska is :
    if there are dead limbs in the top of the birch trees,
    it's getting rotten in the middle.
    Just about all big cottonwood, are rotten in the middle.
  3. fuelrod
    fuelrod
    Western Maine
    I usually can tell when it hits me on my head:rofl: :lol:
    Gark, Ralphie Boy and HDRock like this.
  4. bear_hunter
    bear_hunter
    indiana
    How long do you have before your birch starts to rot after it has been cut and split ?
  5. fuelrod
    fuelrod
    Western Maine
    Hope I didn't mis-speak with that, I did not (can't) watch the video.
    CoreyB likes this.
  6. fuelrod
    fuelrod
    Western Maine
    Once split/stacked, the Birch is stable just like any other wood.
  7. CoreyB
    CoreyB
    South east iowa
    No, the video just showed that I do a vertical plunge cut from the back in the direction of the intended fall.
  8. fuelrod
    fuelrod
    Western Maine
    That makes perfect sence! Hollow tree's can do some weird chit.
  9. CoreyB
    CoreyB
    South east iowa
    Yes they can and sometimes the risk is not worth the fire wood.
  10. redneckdan
    redneckdan
    Northern Minnesota
    Logarithms.
  11. haveissues
    haveissues
    Hudson Valley
    I like that you mentioned to do your test perpendicular to the notch. No reason to give a barber chair a head start. I've seen some rotted out trees that you would have never guessed by looking at them.
    Ralphie Boy and CoreyB like this.
  12. CoreyB
    CoreyB
    South east iowa
    Ya those hickory trees can be some nasty barber chairing buggers without any help.
  13. bogydave
    With the watertight bark, it just has to be split so it can dry
    I split everything , even the 3" stuff
    When dry, & kept dry, it'll last forever like most wood
    bear_hunter and HDRock like this.
  14. lukem
    Yup. And always do it above the notch and back cut. If it is hollow above then it surely is below....not necessarily vice versa.
    CoreyB likes this.
  15. Backwoods Savage
    We've left it up to 3 months but I would hesitate to go beyond that before splitting it. Once split, it keeps just fine. Otherwise it rots from the inside out.
