Rolling log rack
Discussion in 'The Wood Pile' started by Norky, Nov 4, 2015.
  1. Norky
    Norky
    About 6 years ago, a friend made 4 log racks for me. 3- 6'X6' and 1-5'X5'. For a long time I've wanted to put some wheels on one of them and finally got around to it this week. It worked out pretty well, but I can't put as much wood on it as I thought I'd be able to. With the wood stacked 4' high, it's almost at the limit where I can still push it around. Hopefully, I'll be able to get more on it when the wood's split. Either way, it will be nice to roll this much wood from the shed to the back door. Anyone else make something like this?
    wildwest, Todd 2, Eric VW and 13 others like this.
  2. Jon_E
    Jon_E
    Southwestern Vermont
    What's the size of the casters? A larger caster will allow you to move more weight, more easily. You just have to be able to get the cart moving. Probably no different than getting your manual-transmission car push-started. Car weighs 2 tons but it has 28" diameter tires so very little rolling resistance. I bet a 6" caster would make it much easier to push that thing around.
    What you have there, using my best SWAG, is close to half a ton. 6' long, 4' tall stack of 20% MC American Elm, 35 pounds per cubic foot, cut to 16" length, you have more or less 25 cubic feet of solid wood on the cart so 25x35 = 875 lb and give an allowance of 125# for that solid-looking cart and there's your half ton.
    Eric VW, Ashwatcher, Stinny and 4 others like this.
  3. Norky
    Norky
    The wheels are 4"
    I was pushing it up a slight grade, so I'm sure that's a big factor in being able to push it. When I'm moving splits to the house, it will be all downhill, so I'm sure I'll be able to come close to filling it up.
    Eric VW and NH mountain man like this.
  4. Pyroholic
    Pyroholic
    mid michigan
    If you can't push it up the hill you may not be able to stop it going downhill.
  5. NH mountain man
    NH mountain man
    WMNF N.H.
    Might be some good pics of that!:startled:
    Eric VW, Stinny, milleo and 2 others like this.
  6. Norky
    Norky
    I won't let that happen. The driveway is fairly level, it just has a slight slant to it and when I'm pushing that much weight, the slant is noticeable.
  7. haveissues
    haveissues
    Hudson Valley
    Put a hitch on it and use the tractor to move it?
    Eric VW, NH mountain man and Norky like this.
  8. DaveGunter
    DaveGunter
    Here is a pic of rolling rack built by Mitch Newton he shared with me in a thread about moving wood into my basement. Building a couple is on my to do list.
  9. WVhunter
    WVhunter
    Mountains of WV
    Very nice, I agree try some bigger casters. Don't get it to heavy and get hurt.
  10. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    I am not a smart man. My rolling log rack would be my wheelbarrow and my rickety ole back.:)
  11. bogydave
    Awesome
    Good friend !
    Great work saver
    +1 on try the bigger diameter castors .
    You have snow & ice to deal with ?
    See green leaves, where you located ?
  12. Norky
    Norky
    It's a great friend and I may make a companion for it next year.
    I'm getting the hang of maneuvering this thing and I think these casters are going to work well. They roll over debris pretty easily too. I think bigger casters would make it too tall to be stable and as it is the top of the rack just barely clears the lights on the covered patio.
    We get snow and ice, but that won't be a problem. I only have to move the rack about 20' to bring it to the door and only 5' of that is outside and I always keep that area cleared.
    I used it today to bring wood to the splitter and and it was a huge help. It's filled up now, sitting next to the splitter and waiting for next time
    I'm in Northern Kentucky.
