What's the popular pellet for this year ?
Discussion in 'The Pellet Bag' started by Russell, Sep 14, 2015.
  1. Russell
    Russell
    South Coast , Massachusetts
    Do you agree with these BTU ratings ? Just curious . :smoke: WoodBTUComparisonChart.png
    imacman likes this.
  2. will711
    will711
    Pocono Mts.
    I would think they are fairly accurate ,who did the chart??
  3. Russell
    Russell
    I just did a search for wood pellet heat values and grabbed that pic from all the charts they had . The reason is that La Crete which is Spruce post a high btu close to Dog fir , but is much lower on this chart .
    imacman and SKEETER McCLUSKEY like this.
  4. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Seems about right. I can never get any heat out of spruce In my stove it seems
    SKEETER McCLUSKEY and Russell like this.
  5. subsailor
    subsailor
    Winthrop, Maine
    I can attest the Cretes are hot. Spruce Pointe is another like the Cretes. I assume they're spruce based on the name but I've never checked. Don't see them in my area.
  6. Scot Linkletter
    Scot Linkletter
    Athens, ME
    Looks like a comparison of dry btu/lb for the one item they're promoting vs. as-received btu/lb for the rest. The bottom 6 are not dry btu/lb values.
  7. jtakeman
    Shhhh, Don't give away their secret. :eek:
    Just Kidding.....
    Always gotta make yours stand out from the crowd! Whether its just a little white lie or slight deception....... :doh:
  8. Russell
    Russell
    Finally broke down and put a bag of Vanderhoof's Platinum in , set the stove to low . So far very nice heat of 300 from vent and 425 off center glass keeping the house evenly heated . The glass is staying fairly clean and ash is moderate considering it's running on low . The smell of the pellet / earthy is stronger than Blazer and LaCrete put not unpleasant . Also fines are next to nothing and pellet is very durable . :yes:
  9. ttdberg
    ttdberg Pellet Pig
    CT
    I really like these a lot too. They smell great! Mine are a mix of long and short, some of them are ~1.25 inches long. The glass definitely remains clean longer with these than some other brands.
  10. jtakeman
    I like these a lot too, Decently priced locally as well.
    I get confused with these and you know who's platinums. Might be better if they called them something else to eliminate any confusion? I'm gonna say Vanderhauf's to help when I comment on them.
  11. Russell
    Russell
    Sounds like a plan just did my edit to Vanderhoof's Platinum pellets.
  12. Russell
    Russell
  13. DuelburnJake
    DuelburnJake
    I really liked the Okanagan platinums, hasn't been cold enough to throw the LaCrete's in yet and the Douglas Fir is going to wait until its really cold. Burning up the rest of our left over TSC/MWP of which i still have around 28 bags. I don't think I've gone through more than 5 bags yet this season!
  14. Russell
    Russell
    I hear ya I'm just doing some testing so I can add 1 more ton to top things off . Also I'm heating the house from the basement so I can get away with using the hotter pellets earlier in the season .:D
  15. ttdberg
    ttdberg Pellet Pig
    CT
    Can't wait to hear which product you decide to go with. I have a feeling I know what it will be, but will remain quiet so as not to influence the judge's final decision...
    :popcorn:
  16. Russell
    Russell
    LACRETE ! Very HoT ! Very Clean ! cb 1200 med. setting feed gate wide open . Downstairs temp set at 75 swing # 7 330 from vents , 460 center glass . low setting 305 vents , 407 center glass . Did not show any hazing until 5 hours in which was very slight . Turned stove to low in less than 1/2 hr of running test . So far clearly the top pellet I've try so far . :coldfire:
  17. ttdberg
    ttdberg Pellet Pig
    CT
    Had a funny feeling about this one. Time to go get you some more?
    :MM:
  18. CleanFire
    CleanFire
    Roasting LG Granules here after the La Crete bag test this past weekend - will try to put some temps / #'s up this weekend..
    Saving the La Crete's for when it gets colder. :shiver: .. Got to pick up much more! :D :vulture:
    Nice! Thanks for posting the numbers & locations taken! :yes:
  19. Pete Zahria
    Pete Zahria
    New Hampster
    Dan
  20. DuelburnJake
    DuelburnJake
    Only fires
    No I'm really excited to try them out! Hanging in with warm temps here still. Thanks for the great review and info! :thumbs:
