Which is the best ash vacuum?
Discussion in 'The Wood Pile' started by Bill Lion, Nov 2, 2015.
Tags:
  1. Bill Lion
    Bill Lion
    Greater Hartford, CT
    I'm finally buying an ash vac and am not sure which to get. Obviously, I'd like to not pay more than necessary, but I'd definitely pay a bit more for one that is reliable, effective and allows the least amount of ash into the house as opposed to simply the cheapest option.
    Do you have any recommendations of what to buy or avoid? Thanks!
    Mods: Sorry if I posted this in the wrong forum, I wasn't quite sure where it would go.
    clemsonfor and wildwest like this.
  2. haveissues
    haveissues
    Hudson Valley
    I bought the powersmith one last year. I just used it to clean the boiler a few minutes ago and it works great. My only complaint is the wheel mounts are weak and one broke so I took the other 3 off. I don't need wheels anyway so I don't care. No complaints other than that.
    Bill Lion, clemsonfor and wildwest like this.
  3. wildwest
    I have seen in the past on black friday sales at amazon.
  4. clemsonfor
    If I use a vac I just wait till cold and use a shop vac. If warm I just shovel out as much as i can
  5. MasterMech
    It is a bit of a gray area. I'll bump it over to the firewood forum as it is the busiest and most of our members would be able to see it and chime in.
    However, if you were looking to get your vac hot-rodded by a pistol-packin' chimp :dremel: :dex: or wanted to perhaps get a couple smaller vac s to run as backups to the main suction generator, and maybe one really big one just in case, the guys in Chainsaw would certainly be ready and willing to assist! :saw: :loco: :crazy:
  6. Bill Lion
    Bill Lion
    Thank you, I'm definitely considering that one. It's def that one that keeps coming up most on searches.
    I was curious how that compared to the modes that cost twice as much like the Loveless Cougar or Cheetah. Also I wondered how it might compare to the comparably priced Bad Ash 3 which uses the HEPA filtration system (we have some allergies in our home). Anyone try any of these?
  7. Bill Lion
    Bill Lion
    Ha, ha! Thank you
  8. Flamestead
    Flamestead
    Windsor County, VT
    We have had the Powersmith a couple of seasons and like it.
    On the plus side:
    Good power, good filter, smaller hose/extensions makes it easier to reach back into crevices on the PH, long electrical cord, sturdy construction.
    Less than ideal:
    Hose is short enough that I can't set vacuum on the floor and reach down into the top of the PH, so I have to hold it while cleaning out the top.
  9. Bill Lion
    Bill Lion
    That's very helpful; thank you
    wildwest and clemsonfor like this.
  10. Elderthewelder
    Elderthewelder
    Washington State
    wildwest, Bill Lion and clemsonfor like this.
  11. Bill Lion
    Bill Lion
  12. Bill Lion
    Bill Lion
    OK, just bought the Powersmith for $73 on Amazon -thanks for all the help!
  13. Bill Lion
    Bill Lion
    Update: I just used my new Powersmith for the first time and it worked great! Super easy and quick to start using out of the box and very effective. It was much quicker than scooping out the ashes with the shovel and MUCH less messier. I was concerned that this might not be as good as some of the higher end Loveless models, but so far so good!
    Now if only the could would return I can burn again and make more ashes to test the Powersmith further! :whistle:
  14. clemsonfor
    If you burn 24/7 how do you suck ashes out?
  15. Bill Lion
    Bill Lion
    Good question. My insert cuts my oil consumption down by 1/2 so I don't actually burn 24/7. It runs all waking hours, but I don't load past bedtime. On days I want to clear the ashes I always start my last reload fairly early and then max the airflow overnight so I don't have too many hot coals in the AM.
  16. clemsonfor
    Oh. I burn 24/7 and just take what I can out. Sometimes if warmer let cool more to get more of them out
    wildwest and Bill Lion like this.
  17. Bill Lion
    Bill Lion
    Yeah, don't get me wrong, unless I'm sleeping the fire is rocking! I just try to plan a day each week where I can clean it -I've dubbed that day "Ash Wednesday"! :D
  18. sir_saws_a-lot
    sir_saws_a-lot
    St. Law. Cty
    Here we use two different buckets, I have a metal bucket on a cinder block the coals go in, then use a plastic 5 gallon pail for the ashes. Once everything's clear usually I toss the coals back in and refire
  19. clemsonfor
    Welcome sir saws!
    I just sift as many coals out as I can and try for the ash. I usually use a plastic five gallon bucket. Its warm by the time I toss in garden. Sometimes I have melted through by the time I am outside. I need to get a new metal ash bucket. The old rusted out
  20. Bill Lion
    Bill Lion
    I used a metal ash bucket until I got my ash vac this week -worked fine. Except I kept filling the room with ash!
