Lit stove from coals in 5 minutes from 16 hour old coals!
Discussion in 'Modern EPA Stoves and Fireplaces' started by raybonz, Dec 29, 2013.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Last night I got the fire lit in 5 minutes from a fire 16 hours earlier! Have to say this is impressive! Got fire going at 4AM before work maybe 1/2 load then relit fire at 8PM from coals from the 4AM fire and only took 5 minutes.. The T-5 never ceases to amaze me.. Of course the wife couldn't care less but I thought you guys could appreciate this :)
    :thumbs:
    Ray
    Trilifter7, Gark, HDRock and 10 others like this.
  2. papadave
  3. fox9988
    fox9988
    NW Arkansas 72717
    PE 's have impressive burn times. If I were to switch to a re-burner, it would be a T-5.
    raybonz likes this.
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    There's some truth to that too Dave.. I have been burning hard maple mixed with some red oak which is a good coaling wood, maple not so much.. Around here we have lots of good wood so I'm fortunate..
    Ray
  5. raybonz
    raybonz Moderator
    Carver, Mass.
    The T-5 employs a S/S baffle rather than tubes maybe that has something to do with the efficiency? I heat 1600+ square feet with a 2.0 cu. ft. firebox very well and the stove is not working hard gives plenty of heat and long burn times..
  6. rdust
    rdust
    SE, Michigan
    Nice burn! The PE stoves are one of the lines I'd love to test drive.
    raybonz likes this.
  7. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Don't all modern stoves do that? Hot coals after 16 hours enough to re-start. I have only used two fire starters the whole year so far.
    Trilifter7 likes this.
  8. raybonz
    raybonz Moderator
    Carver, Mass.
    I don't think so.. Some yes and some no..
  9. fox9988
    fox9988
    NW Arkansas 72717
    At 2 cuft, I don't think so. Many have a hard time getting an overnight burn.
    Chvymn99 and raybonz like this.
  10. Todd
    Todd
    NW WIS
    16 hours on a half load? That's Blaze King territory, impressive indeed.
    Tenn Dave and raybonz like this.
  11. NortheastAl
    NortheastAl
    Putnam County NY
    That it impressive, Ray. My Endeavor will do that on rare occasion with it having to be a full load to start. Usually, I can consistently get 10 hours and sometimes 12.
  12. Chvymn99
    Yep, that's impressive. 10-12 is ideal on a full load for my NC30, so far. Any more than that I'm grabbing a firestarter, to jump start it.
    NortheastAl and raybonz like this.
  13. bogydave
    Nice to get all night Burn cycles. :)
    To warm up here , mid 20s day time
    What are your temps?
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    Weather has crazy so far here but even when cold which would be warm for you I generally run the stove with very low air..
  15. bogydave
    Yuk
    Looks like you have a cold front coming later this week :)
    raybonz likes this.
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    Now you know what I mean about the weather here Dave.. Harder to run the stove when it's just cool out.. Have it running right now to take the chill off and the challenge is not getting the house too warm..
  17. bogydave
    +1
    I have had to open window to keep the temp inside livable
    Wife gets mad , but if above 75 I have to cool it down some.
    We are forecast for mid 20s day, mid teens at night.
    Constant mild temps that are easier to burn for 72° Temps.
    Unless the winds pick up.
    raybonz likes this.
  18. jeff_t
    jeff_t
    SE MI
    The PE Super Series stoves have a linked primary and secondary air control. As the primary air is cut back, so is the secondary air, to a point of course. Makes for good control, and some looong burns.
    My stove seems to breathe really well. From a cold start on Friday (by cold, I mean below freezing INSIDE :eek:), I was turning the air back within ten minutes, and had a 400° stove top in less than twenty. That's with a top down start and really dry white ash. I blew threw that load in about six hours, but the next load of oak went for over twelve, with air wide open for the last 2.5-3 hours to burn the coals down.
    I find that I can burn ash with the air closed all the way, but a full load of oak needs just a bit more. Otherwise I lose secondary burn and get smoke. It could just be that the oak isn't as dry as the ash. That extra little bit of air does make for some 650-700° temps, though :fire:
    fox9988, papadave and raybonz like this.
  19. Todd
    Todd
    NW WIS
    I'd love to try out a T-5, great stove! -20 tomorrow morning and it looks like the next couple days won't break 0! I'm pretty confident my little Keystone will do just fine for my 1200 sq ft.
    fox9988 and raybonz like this.
  20. raybonz
    raybonz Moderator
    Carver, Mass.
    Keystone and all other WS stoves are great heaters and beautiful too!
    fox9988 likes this.
