Fire extinguishers !
Discussion in 'Everything Else (off topic)' started by Deacon, Oct 31, 2015.
  1. Deacon
    Deacon
    Eastern Nebr.
    Just a friendly reminder to check your extinguishers.
    Mine seem to get old FAST.:doh:
    Cheap insurance & peace of mind.
    New one alongside a 6 year old one.
    :sherlock::sherlock:
  2. wildwest
  3. UncleJoe
    UncleJoe
    SC Pa
    Got one in every room and 2 in each of the stove rooms.
    They're an essential item for any home whether you heat with wood or not.
  4. hossthehermit
    hossthehermit
    Where the bush is green ..........
    Make sure ya keep 'em by the EXIT DOOR from the room. Don't go into a fire to get the extinguisher ........... I've seen so many behind the stove so they are "out of the way" ..............
    HDRock, Deacon, unclefess and 2 others like this.
  5. CNE deer
    CNE deer
    ohio
    +1 Deacon I have 2 but need to check dates.
    Deacon and Flatlander Pete like this.
  6. basod
    basod
    Mount Cheaha AL
    ABC dry chemical extinguishers should be inverted every month or so to ensure the chemical doesn't settle and cake over.
    Flatlander Pete likes this.
  7. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    That's a great reminder Deacon. Thank you!
    basod, I had no idea I should invert them. Thanks for sharing! Mine are 3 years old and going to get inverted for the first time today. Silly question, should I be able to feel the chemical "slosh" around?
    Deacon, unclefess and basod like this.
  8. basod
    basod
    Mount Cheaha AL
    You may/not feel something.
    We have ~60 extinguishers at work that get inspected monthly. There are only a few of the ABC's that I've ever really felt any sloshing.
    As far as expiration dates go it's really just for a hydro test on the steel cylinder, if the gauge shows good pressure it's probably good to go
  9. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    Thank you sir!
  10. Deacon
    Deacon
    Eastern Nebr.
    My wife & I always give young couples the same two housewarming gifts.
    Fire extinguisher & a plunger!
    When you need them you need them RIGHT NOW!:eek:
  11. yooperdave
    Good advice. How would you have one re-charged? It has never been used but the indicator needle is in low or recharge position.
    Deacon, Flatlander Pete and wildwest like this.
  12. basod
    basod
    Mount Cheaha AL
    Just buy a new one. The neck seal is probably slowly leaking.
    Unless it's a large one probably not cost effective
