Mobile home hearth project
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sequoia, Oct 30, 2015.
  1. Sequoia
    Sequoia
  2. chance04
    chance04
    Denton Md
    I like the colors! Nice work
  3. TurboDiesel
    Can't wait to see it finished, Sequoia
    What kind of stove you got?
  4. Well Seasoned
    Looking good so far! :thumbs:
  5. Canadian border VT
    Great job Sequoia :yes: looking real good, not trying to mother hen, but be careful of clearances to paneling in back...
  6. Sequoia
    Sequoia
    Blaze king princess ultra
    Doug, Todd 2, HDRock and 3 others like this.
  7. Sequoia
    Sequoia
    I appreciate that I'm installing a Blaze princess ultra made for clothes clearance installation
  8. Sequoia
    Sequoia
    Dang! that dictation isn't always accurate
    raybonz, savemoney, HDRock and 4 others like this.
  9. Canadian border VT
    don't worry about it my auto correct gets funny thing too:handshake:
  10. TurboDiesel
    you got a little time to go back and edit it
    thats gonna be a great set up :yes:
    wildwest and Sequoia like this.
  11. Backwoods Savage
    I'd probably still put something on that wall.
  12. TurboDiesel
    x2
    even just stand a sheet of concrete board there
  13. HDRock
    Looks good
    :popcorn:
  14. Sequoia
    Sequoia
    The stove will sit at a 45 degree like an alcove setup. The back corners of the stove will be 8inches from the wall and back of the stove will be at least 12 inches from back corner of hearth. Plus I'll have a blower on the back which acts as a heat shield and it will have side shields. Based on your collective knowledge, will this be adequate clearance?
  15. wildwest
    I would base it on the last two posts,
  16. HDRock
    Go by the manufacturer specs.
    This is not really relevant but a dealer near me has a princess setup with single wall pipe and you can put your bare hand on that pipe when the stove is cruising
  17. Sequoia
    Sequoia
  18. HDRock
    looks like in the manual, a reduced corner installation, your sides are two inches farther than required 6"
    in the mobile home you are required to have a outside air kit also
    raybonz and wildwest like this.
  19. basod
    basod
    Mount Cheaha AL
    I was wondering about the hole in the hearth - looks like it's all setup for one
  20. Sequoia
    Sequoia
    Yes that's what it's for. Plus the grounding wire passes through this hole.
    raybonz, wildwest, HDRock and 2 others like this.
