High temp silicone
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 29, 2015.
  1. Geek
    Geek
    I cannot believe that neither Home Depot nor Lowes have any selection on it?
    I was looking for clear amall tube and a black one.
    Lowes has one red color.
  2. jtakeman
    Local hardware will most likely have Rutland clear and black.
    Both Ace and true value do.
    bogieb, slvrblkk, wildwest and 3 others like this.
  3. Geek
    Geek
    I will check Ed'd hardware later today, meanwhile this morning I bought a 'regular' clear silicone that states it holds temps up to 400F. Should that one be ok?
    Got it from a local lumber hardware supply.
    slvrblkk and wildwest like this.
  4. wildwest
    I ordered mine on the internet. It's HomeSaver brand, black and says 500*
  5. ttdberg
    ttdberg Pellet Pig
    CT
    TSC carries the Rutland high temp silicone, and any stove shop should have some as well. I prefer the really small tube because every time I get one of the caulk gun size ones, I use it once and the rest goes to waste because it turns into a chunk over time, no matter how I try to protect it after use. I think the Rutland silicon and the rescue tape stuff is both rated for 500. Not sure 400 is good for a stove pipe application. Maybe the rescue tape would work for what you need?
    Russell, slvrblkk, Geek and 2 others like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    Like tt said the 400 might be borderline....auto parts stores should have what you need too.
    Russell and wildwest like this.
  7. jtakeman
    Permatex ultra's are rated for 650°F or higher. I used ultra black on my venting before I found the Rutlands.
    Rutland is like 800°F IIRC.
  8. Geek
    Geek
    Thanks guys, I will head to Ed's hardware to see what they have. I would think 400F would be fine and wouldn't think the pipe would get THAT hot, but better be safe than sorry I guess.
    Russell, eatonpcat and IHATEPROPANE like this.
  9. Geek
    Geek
    slvrblkk, jtakeman and Russell like this.
  10. jtakeman
    Russell, slvrblkk and Geek like this.
  11. Geek
    Geek
    I saw that one but not available. The pipes are stainless steel so want to use clear silicone.
    Thanks,
    will711 and slvrblkk like this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You do not use stuff that can handle the normal operation of the device it is always for the abnormal conditions that you choose sealant. Normal operation is always way under in terms of temperature than a runaway fire situation. Read and follow the manual and remember those are minimum requirements.
    jt is correct the black Rutland is rated 800 degrees Fahrenheit and is the only sealant I use as it remains somewhat flexible. If you are using sealant on a joint you are going to be opening on a regular basis find some self fusing silicon tape rated to at least 500 degrees Fahrenheit.
    A mistake here is not as easy to recover from as a backwards leaf blower episode and can if push comes to shove result in death.
    343amc, IHATEPROPANE, Russell and 2 others like this.
  13. Russell
    Russell
    South Coast , Massachusetts
    ttdberg and imacman like this.
  14. CleanFire
    CleanFire
    That's good stuff, what I used on the wood stove here when re-gasketing.
    Russell likes this.
  15. subsailor
    subsailor
    Winthrop, Maine
    I bought a tube of Rutland black today. $4 and change. Local store didn't have the clear.
    slvrblkk and Russell like this.
  16. Geek
    Geek
    This was the best I found at local Ace...
    CleanFire and slvrblkk like this.
  17. subsailor
    subsailor
    Winthrop, Maine
    Hmmm, I just noticed the tube I bought is 2000*. Anybody know if this will be an issue?
    eatonpcat, CleanFire, bogieb and 2 others like this.
  18. slvrblkk
    slvrblkk
    Northampton, PA
    Might be borderline too....lol
  19. smoke show
    smoke show
    Pittsfield, Wi
    If a little us good a lot is better!
  20. bogieb
    2000*? Yeah, you'll be fine (I want some of that :D). 200* - you might want to rethink using it.
    Russell, CleanFire and slvrblkk like this.
