1st full cleaning of the season
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by slvrblkk, Dec 27, 2013.
  1. slvrblkk
    slvrblkk
    Northampton, PA
    After burning a little over a ton, I decided to take her out and give her a good cleaning today. Hands down, nothing beats compressed air to blow these thing out. One thing I noticed was how little ash was inside this thing but it was probably due to the LBM I gave it the other week. The only thing I didn't do was pull the combustion blower but I got it pretty good with the long flexible air gun that I have. I might wait until I burn at least a ton and a half next time before I give it a full cleaning again.
    IHATEPROPANE, gbreda and will711 like this.
  2. will711
    will711
    Pocono Mts.
    Steve I don't know how you do it , but my stove ain't never going outside for a cleaning at 400 lbs. unless it grows a set of legs :rofl: :lol: it gets cleaned inside:)
    343amc, brokenwing, eatonpcat and 2 others like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    I have a hand truck for the stove and ramps to get it out of the house. I'm thankful the stove isn't heavier!!!
  4. will711
    will711
    Pocono Mts.
    Nice set up, compressed air gets in those areas the vac can't get to:)
    slvrblkk likes this.
  5. bogydave
    Super clean,
    I need to pull the pipe & clean the cat chamber out this summer.
    I like having the ash fill the nooks & cracks around the bottom.
    Fills in around the fire brick seams .
    Shoveled mine out today too, but left lots of hot coals & got a new load burning . -2°
    gbreda likes this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    damm! brrrrrr! :D
    will711 likes this.
  7. Hoot23
    Hoot23
    Alfred, ME
    Cleaning Sparky today. This upcoming week is going to be chilly. Low teens and single digits. Doing it inside though!
  8. gbreda
    gbreda
    NH
    Same here. Did a full cleaning including venting a week or 2 ago, so today will be firebox only and wont take but a few minutes after it cools enough
    slvrblkk and Hoot23 like this.
  9. imacman
    imacman
    Denver, NC
    Yep, probably a good time for most people to give the stoves their first full cleaning this season.....I imagine most stoves have gone through either a ton, or close to it. Cold weather is on the way.
    gbreda and slvrblkk like this.
  10. DexterDay
    I still have a little left to go on my cleaning... Been working 12 hrs, or I would update my 1 ton burn, cleaning thread.
    Moving a stove outside is a little tough for most, but if you can't? Hook the Leaf blower to it. The best way to clean a pellet stove is with compressed air. Put Leaf blower on outside and use compressed air from inside the house (no need to disconnect). This keeps you from moving the stove.
    Steve, Bet she is burning good now? :)
    savemoney likes this.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    You better believe it!!!
  12. savemoney
    Brilliant ! I hadn't thought of that but it sound like it is worth in. I set the leaf blower in place, and have a remote control on off switch. This would work well with your idea so I wouldn't be overdoing things with the leaf blower.
    DexterDay likes this.
  13. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I was in the same boat today. I have some pellets that are kicking out alot of ash. I do not move that heavy beast, but it got a good overhaul today.
    will711 likes this.
  14. will711
    will711
    Pocono Mts.
    Just waiting for my stove to cool down and it will get a quick clean today . I cleaned it once this month already ,but it warm here today so I'll take advantage of that :)
    Hoot23, slvrblkk and gbreda like this.
  15. will711
    will711
    Pocono Mts.
    All clean now :)
    gbreda, DexterDay and slvrblkk like this.
  16. slvrblkk
    slvrblkk
    Northampton, PA
    Time for some beers...:D
    DexterDay and will711 like this.
  17. will711
    will711
    Pocono Mts.
    That is correct :thumbs::drunk: followed Smokie's :) advice finish cleaning now the drinking:D
  18. will711
    will711
    Pocono Mts.
    Hopper filled with Hamer's Hot Ones , and man they are Hot usually I can hold my hand on top of the stove not now :thumbs: unless I want a burnt hand :eek:
    nothing like a fresh cleaned stove;)
  19. IHATEPROPANE
    IHATEPROPANE
    Just finished my second LBT for this season. Wasn't as dirty as the first time around but wanted to sneak it in while the temps are nice.
    I also put a tach on the combustion blower while doing it.......it only turns at about 100 RPM for those interested :)
  20. smoke show
    smoke show
    Pittsfield, Wi
    can't be only 100???
