Stihl 019T crankshaft needed...
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Oct 27, 2015.
  1. Scotty Overkill
    Well after the saw stumping me endlessly, I finally figured it was most likely an ignition or timing problem
    After it let down a couple weeks back, I finally took it to a reputable Stihl shop in my area, and he came to the conclusion that the crankshaft is tweaked or twisted and knocking it out of time.....that said, I'm on the hunt for a used crankshaft to see if he's right.
    Not Sure if the MS191 or 192 shares the same crankshaft, can anyone help out here?
  2. Bret Hart
    Bret Hart
    Central NY
    Not the same number.
    019 t crank - 1132 030 0401
    ms191t crank - 1132 030 0402
    ms192c crank - 1137 030 0400
    ms092t-ms-tc crank - 1137 030 0400
    SquareFile and Scotty Overkill like this.
  3. Bret Hart
    Bret Hart
    Central NY
    The crankshaft part number for your 019t is also used in these saws:
    017
    ms170
    ms190t
  4. Scotty Overkill
    Awesome!! Because I have a 170 that has a bad piston /cylinder! I'll just use that crank.....
  5. papadave
    Solution in 1/2 hour.:dex:
    Is that a record or something? Gotta' be a record.
  6. Scotty Overkill
    Now if I could just get it to fix itself, we'd be golden!!!
  7. MasterMech
    Well done sir. :yes:
