BG55 No Start
Discussion in 'Chainsaws and Power Equipment' started by lukem, Oct 26, 2015.
  1. lukem
    I have fuel getting into the cylinder...and spark....and compression. ..but she still won't even pop. What next?
  2. cnice_37
    cnice_37
    You probably know more than I do... but FAST - fuel air spark & timing - did your key get sheared?
    Check the exhaust for carbon buildup... swap plugs.
  3. lukem
    Swapped plugs from the trimmer and same thing. I didn't check the key but I suppose anything is possible.
  4. Bret Hart
    Bret Hart
    Central NY
    Some info on that power head for the BG.
  5. MasterMech
    Canuit valve is probably chooched behind the muffler bearing. See if the capacitance of the blinker fluid has been altered off its factory spec and check for termites in the backplane.
  6. lukem
    Probably the Flux capacitor dun chit the bed.
    MasterMech likes this.
  7. DexterDay
    Getting fuel and having enough fuel are two different things.
    How old is the unit? Fuel line is a likely culprit? Carb clean would be on the short list of things to do as well.
    Have you tried to prime the carb with fuel?
  8. KaptJaq
    KaptJaq
    Long Island, NY
    When I have a small engine that refuses to pop I usually put a little starting ether in via the air intake. If that doesn't pop then there is a real problem. The ether usually runs rough for a few seconds and loosens up whatever the problem was.
    KaptJaq
  9. lukem
    It is about 4 years old. Plug gets wet it I tug on it enough.
  10. MasterMech
    Then it should fire at some point. I would say you either have a VERY plugged exhaust or inadequate spark. Compression was verified with a gauge?
  11. lukem
    Exhaust is fine. I didn't test with a gauge but it feels the same as it always has. How do you know if your spark is strong enough? Never had a weak spark issue...:confused:..but I've heard of them.
  12. MasterMech
    Without a gap tester, I'd check the air gap from the flywheel to the coil and remove the kill wire to eliminate any switch or grounding issues.
    Certified106 and lukem like this.
  13. super3
    super3
    DexterDay likes this.
  14. DexterDay
    Nice tool. Mine is a simple spark tester. I love how you can adjust that one!! :thumbs:
