ATV fuel problems
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Oct 24, 2015.
  1. bogydave
    Got to the tank
    Draining:
    Can see lots of stuff in the bottom of the tank.
    Def needs cleaned.
    Will report progress.
    48° but 30 mph wind gusts
    Good to be doing it in the heated shop , not in the middle of the woods with few tools.
    Loon, Eric VW, clemsonfor and 3 others like this.
  2. papadave
    Time to start filtering the fuel as it goes in?
    Eric VW and clemsonfor like this.
  3. bogydave
    Yea, a screen on the jugs would help.
  4. bogydave
    Progress
    Wasn't as hard as I thought. Came out relatively easy.
    Can see the on/reserve stand pipes
    Tank out, no easy way to fully drain or clean:
    Problem:
    Founds a dead bug & parts, small pieces of clear & red plastic, dirt & looks like fine wood chips. (no water)
    Few years ago I added an inline fuel filter.
    Cleaned the high/low filters & the tank best I could:
    back together:
    Well Seasoned, Loon, jo191145 and 3 others like this.
  5. papadave
    Runnin' gooder now, I hope?
    Eric VW and HDRock like this.
  6. bogydave
    Hope that was the problem.
    Didn't take the off/reserve/on valve apart, the screens should keep the ports on it clean
    When it quit in the woods, I pulled the fuel hose to the carb , no fuel & the tank was over 1/2.
    Gravity feed so I figured something had the fuel source plugged.
    After I blew back thru the hose to the tank, fuel started running again.
    14 years of accumulation of stuff.
    Eric VW, clemsonfor and papadave like this.
  7. HDRock
    Good Deal
    and you thought you were going to get the day off:)
    Eric VW and papadave like this.
  8. bogydave
    Makes me think I should check the saw's fuel screen
    soon. Saw a head ache in the woods.
  9. papadave
    I went a little farther with my thinkin' that he might need to get a new 4wheeler. :dancer:
  10. bogydave
    Though it isn't hard on the back, arms & shoulders.
    Just hard on patience , figuring out how to get things apart & back together. :)
  11. bogydave
    Yea
    One with power steering.
    Over 1/2 the arm & shoulder soreness is from fighting the steering thru the woods.
    Cut some , load some helps but in 4 wheel drive,
    it's a bear to turn
    & backing up the trailer in the woods is next to impossible
  12. papadave
    One word..........UTV.
    Another word.....steering wheel. Ok, two words.
    Well Seasoned and Eric VW like this.
  13. bogydave
    New UTV, then need a new trailer
    Just add $$ LOL
    Become a snow bird, might be cheaper :D
  14. papadave
    Yep, just like that.
    Shazayam!
  15. clemsonfor
    Thats why I like the older smaller ones!
    Eric VW likes this.
  16. clemsonfor
    Yea I have no idea why they didnt put inline filters on these things. When I got my honda 300 it had a clogged up carb. There was all kinds of rust dust n particles. Only the mesh screen thats on the on/reserve
    Eric VW likes this.
  17. TurboDiesel
    ^^^this^^^
    love my power steering!!!
  18. TurboDiesel
    because nobody would pull the covers off and change them until they were clogged anyway?
    jo191145, Eric VW and clemsonfor like this.
  19. clemsonfor
    I put mine so I can just reach in there and pull it out. And I can see it if I look from side. Its a larger size one. Would take a lot of crud to stop it up
    TurboDiesel likes this.
