Sooteater rocks!
Discussion in 'Modern EPA Stoves and Fireplaces' started by DuelburnJake, Oct 21, 2015.
  1. DuelburnJake
    DuelburnJake
    I didn't belive it. Here is a before and after. I waited all summer to clean so the creosote fell.
    Chvymn99, HDRock, wildwest and 2 others like this.
  2. Eric VW
    Amazing!
    Was that after a hard heating season with questionable wood, or is your chimney built to the exterior of the house?
    I use a pre- epa stove with somewhat questionable wood and only the top 4 feet(above roofline after chimney exits interior routing thru our house) gets any noticeable build up, mostly "potato chips" and occasional "glossy black" stuff.
    Need to get me a Sooteater.....
  3. bushpilot
    bushpilot
    Eastern Washington
    I've been thinking of getting one, thanks for posting this.
    Greg
  4. DuelburnJake
    DuelburnJake
    It's an exterior chimney. Interior install was not an option.
  5. mattjm1017
    mattjm1017
    That is/was some nasty build up there! Was that from one season of burning? I think that I am now sold on the sooteater:yes:
    HDRock, DuelburnJake, Eric VW and 2 others like this.
  6. DuelburnJake
    DuelburnJake
    That was a season of burning. The exterior chimney and extreme cold temps didn't help. It actually looks worse then it was in the picture due to temps fluctuating over the summer causing some of the creosote to fall towards the bottom of the chimney. I checked it after the last fire in the spring and it didn't look nearly as bad. The sooteater rocks though!
    Eric VW, wildwest and papadave like this.
  7. Machria
    Machria
    Long Island, NY
    WOW! That sure is a lot of creo in there! If I was you, I'd do a mid season cleanout!
  8. DuelburnJake
    DuelburnJake
    I'll check monthly now! Its so easy to use and clean now!
  9. mattjm1017
    mattjm1017
    DuelburnJake, wildwest and papadave like this.
  10. DuelburnJake
    DuelburnJake
    Wife got it for me off of amazon.com
  11. wfournier
    wfournier
    Western MA
    papadave and DuelburnJake like this.
