Husqvarna 345
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Oct 22, 2015.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    What is the difference between a 345 and a 346?
  2. SquareFile
    SquareFile
    somewhere
    Crank case, top cover, handle bar, cylinder & piston.
    HoneyFuzz and 94BULLITT like this.
  3. cnice_37
    cnice_37
  4. dougand3
    dougand3
    North Alabama
    One is clamshell, one is pro build.
    94BULLITT likes this.
  5. 94BULLITT
    94BULLITT
    So it is really not a pro saw then. I saw some piston and cylinder kits on eBay that said the 345, 346, and 350 were the same. I'm glad I asked on here. Thanks for the repliesn
  6. dougand3
    dougand3
    North Alabama
    The 346xp cyl is shorter with flat bottom - it bolts directly on the mag crankcase. The 345 cyl is taller with semi-circle bottom - it bolts onto the little clamshell. Now, if they have a spacer with semi-circle bottom - the shorter 346xp jug would work, provided bolt holes line up. The 350 has such a spacer.
  7. 94BULLITT
    94BULLITT
    Here is one I saw on ebay.
    BIG BORE HUSQVARNA 350, 345, 340, 346XP, 353 CYLINDER & PISTON KIT 45MM GASKETS
  8. Jeffrey Svoboda
    Jeffrey Svoboda
  9. 94BULLITT
    94BULLITT
    That is what I was thinking. It looks like the spacer may convert it so other cylinders can be used on it. The saw I am checking into is supposed to be a good runner. I am just trying to figure out my options if it isn't. I've learned my lesson on AM cylinders.
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    Search on arborist site.com for 346xp kit and there is a bunch of info there.
  11. 94BULLITT
    94BULLITT
    I decided to not get the saw. A 346 cylinder can be put on it but you have to use the spacer from a 350.
