Suggested Spare Parts
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by wildwest, Oct 20, 2015.
  1. wildwest
    I am placing an order with Don, and would appreciate your suggestions :)
    Here, I do not have a dealer or any big box stores, all parts will be by mail......So I would prefer to be prepared rather than end up in a hotel room til the parts arrive if something goes out......
    Help me pick and choose and what am I missing?
    ignitor
    burn pot gasket
    exhaust clean out gasket
    door gasket
    blower assy
    vacuum switch
    Thanks!
    CleanFire, ivanhoe and slvrblkk like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    Make sure you get your 10% off discount :yes:
    ivanhoe and wildwest like this.
  3. johninwi
    johninwi
    madison wi
    Control board and fuse's?
    CleanFire, ivanhoe and wildwest like this.
  4. imacman
    imacman
    Denver, NC
    Spare auger motor, comb. blower gasket(s),
  5. wildwest
    ivanhoe likes this.
  6. imacman
    imacman
    Denver, NC
    combustion
  7. wildwest
    Gaskets for the doors with impellars inside? Sorry, my manual uses terms different terms than commenly said :emb:
    ivanhoe likes this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    With that many parts, another stove might be cheaper:whistle: Just make sure to lubricate all what's needed and you might not need anything for a long time. But then again you do run your stove 365 days/year. If you buy a gasket sheet, it might cover most gaskets. Train some hamsters to turn a cage/rubberband in case you need a back-up plan:yes:
    CleanFire and wildwest like this.
  9. wildwest
    Link?
  10. DexterDay
    Ignitor is the prob the most important. Exhaust gaskets can be had almost anywhere and anytime. The blowers and motors get expensive.. If you rely on it as a sole source of heat (we know you burn wood) then having all replacements are nice. But motors, blowers, etc get pricey.
    I will be buying a spare ignitor myself. But with wood and a pellet furnace? I will order other major parts as they fail.
    imacman, slvrblkk, CleanFire and 3 others like this.
  11. ivanhoe
    ivanhoe
    Northern Ontario
  12. wildwest
    Thanks!!
    ivanhoe likes this.
  13. CleanFire
    CleanFire
  14. CleanFire
    CleanFire
    Seriously though, I would just ask Don - he sees a lot of stoves, and can help w/ what you might want to stock,
    +1 on Ignitor, our's is original to the stove, that's on the list here. (But if it failed some starter gel (or even lighter fluid) and hand-priming the pot would do in a pinch.) Also looking at the burn pot, that may be on the 6-12 month replacement list here.
    ivanhoe, slvrblkk and wildwest like this.
  15. IHATEPROPANE
    IHATEPROPANE
    If don2222 stocks the parts I wouldn't have any in advance. Worst case is you get the part you need in a couple of days. Most of your parts will last year's except the igniter. But I am sure you can manually light the stove if necessary.
    DexterDay, ivanhoe, wildwest and 2 others like this.
  16. don2222
    don2222
    Salem NH
    Some Drolet stoves like the Eco-35 model I recently worked on use the SBI Combex blower which is the combination exhaust blower and positive draft blower!
  17. don2222
    don2222
    Salem NH
    Some parts are not very common such as the control panel and Combex blower and are shipped from the US warehouse in Michigan so having those as spares would save a lot of time. Even having an igniter can save time if it burns out on a cold winter night on Friday so shipping can take quite a few days!
  18. subsailor
    subsailor
    Winthrop, Maine
    I'm sure WWW could get the stove lit if the igniter failed but with you running the stove all the time year round, it's not like the igniter gets used much anyway, does it? I would think it would last a while.
    imacman, CleanFire and wildwest like this.
  19. wildwest
    I think all of you offered me some needed common sense. Thank You.
    How might one manually light? Propane bottle torch? Super Cedar?
    slvrblkk and CleanFire like this.
  20. CleanFire
    CleanFire
    Super Cedar would work excellent, lots of box stores sell Starter Gel, just mix a tablespoon or so to 1/2 cup pellets, mix well, and ignite / press start, others have said hand-sanitizer works as well as Starter Gel at a fraction of the cost on the 'other' forum.. Like Purell.
