Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. clemsonfor
    They still make the 372xp . I think thats the only 3xx saw still made. Maybe they still make or have some 395s left???
    The 2xx was obviously earlier. I am no expert but think it was early 90s at least?
    If the saw is clean and has compression esp if its a bigger one its definitely worth $200. Some of those saws are desirable.
    STIHL250 likes this.
  2. Elderthewelder
    Elderthewelder
    Washington State
    thus the reason I had Mastermind put in the H.O. guts into my stock oiler while he was working on it
    Chvymn99 and clemsonfor like this.
  3. Fossil
    Fossil
    Ontario
    The 266XP was made in Oct 1998 Not sue when they went for SE to XP.
  4. STIHL250
    STIHL250
    Pennsylvania
    Well guys official ill be sellin my stihl 250 today like the saw alot but i still feel theres a reason for the heat in the bar im not even gonna try with the dealer hes awesome but gonna save the money from the saw and possibly in time go for the new line of husky xp saws until then just my old homies n pioneer lol so thanks guys for all the info ill keep u posted when i get a new saw it will be a little while for sure but will deff happen:D:dex:
    Certified106 likes this.
  5. STIHL250
    STIHL250
    Pennsylvania
    Btw it will be the first husky ill ever own so i cant wait
    Ronaldo likes this.
  6. clemsonfor
    You looking at the $200 one? Check it out look at the piston and cup at least.
  7. 94BULLITT
    94BULLITT
    Frederick County, VA
    What kind of bar oil were you running?
  8. cnice_37
    cnice_37
    STIHL250 there goes your username :doh:
    A little heat in the bar is normal I think. Metal on metal at 10,000 RPMs, it is what it is. If the driver links show lube after cutting, then you should be all right.
    But get the Husky :D
    p61 western, STIHL250 and Ronaldo like this.
  9. DexterDay
    3120xp, 395xp, 390xp, and the 372xp are the 4 big hitters. The 365 is still made as well.
    p61 western and concretegrazer like this.
  10. Certified106
    Certified106
    In The Hills
    Best bang for your buck is a Husqvarna 555!!!! Or get a Husqvarna 562XP with MMW port job and you will smile every time you look at it.
    Chvymn99, STIHL250 and Ronaldo like this.
  11. clemsonfor
    Yea I forgot about the 365 basically the same as the 372 with different transfers or something?
  12. clemsonfor
    Yea I have the 555 at work. Its my work truck saw. Its a strong torqy saw!! Its a good all around saw.
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    Here are mine. Starting at the top: 372, 445, and 353.
  14. clemsonfor
    I have a 445 . Kind of anemic saw to me but thats probably a result of me running big saws most of the time?
  15. Jeffrey Svoboda
    Jeffrey Svoboda
    It was my first saw and still use it for the small stuff most the time. My only complaint is it doesn't oil very good.
  16. clemsonfor
    Mine is an ok oiler but not great I agree with that.
    I use mine for limbs and tops when its used. Or take as a backup saw to cut one out if I get one stuck.
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    I got the 353 as a back up/play mod saw. Plus you can put a 346 jug on it :thumbs:. After visiting ab site and reading I had to have a 372. Glad I did!! It's an awesome saw!!
    STIHL250, Ronaldo and clemsonfor like this.
  18. 94BULLITT
    94BULLITT
    I put a 20'' bar on the MS 441 CM today.
  19. clemsonfor
    I run a 20" most of the time on the ms650.
    STIHL250 and 94BULLITT like this.
  20. clemsonfor
    uploadfromtaptalk1445471013413.jpg here is a pic with two saws in it. Find them.
    Since I been posting random stuff and no saw pics.
