Help me out here.
Discussion in 'Chainsaws and Power Equipment' started by Gasifier, Oct 17, 2015.
  1. Gasifier
    New Echo 361P. Ran great first time I used it. I thought I flooded it last time I used it when I tried starting it after a break. So it's been sitting for several days. Will not start. Pulled plug. Dry as a bone. Not getting gas? Any suggestions?
  2. man of stihl
    man of stihl
    NW PA
    Is it still under warranty?
    See if it will run with a prime.
  3. TurboDiesel
    primer bulb full?
  4. Gasifier
    Yes. I think I just figured it out.?:emb: Now how do I clean the bar and chain oil out of the system where the gas is suppose to go?:picard:help!
    Hedgerow, HDRock, basod and 11 others like this.
  5. Gasifier
    Yes.:emb::picard::hair: With bar and chain oil.!
    old 040, HDRock, milleo and 2 others like this.
  6. Gasifier
    I have both caps off. Tanks drained and its up side down over a basket letting it drain. How do I get bar and chain oil out of gas line? Will it drain out with time?
  7. TurboDiesel
    ouch...
    Gasifier likes this.
  8. papadave
    Holy canoli Gas.
    That sucks.
    I hope someone can help out.
  9. TurboDiesel
    maybe a little carb cleaner to cut the oil. then run it wide open till it quits smoking
  10. Gasifier
    They are in a different spot than on my CS-680. I was apparently in a hurry.:faint:I don't know how to get the oil out of there.
  11. Gasifier
    I was wondering if I put gas in the gas tank if it might make its way through the oil. ? I'm going to let it sit upside down for a few hours now and go cut with the 680.
  12. Gasifier
    I'm as far from a mechanic as you can get. LOFL
    papadave likes this.
  13. pappy88
    pappy88
    Missouri
    Put gas mix in it & keep pumping the primer bulb till your thumb hurts then dump that & do it again maybe. never been there done that, but that might work. Good luck !
    basod, Moparmyway, Chvymn99 and 4 others like this.
  14. papadave
    Maybe some gas in the correct tank, sloshed around, then dumped?
    Well, pappy beat me to it.
    Gasifier, man of stihl and pappy88 like this.
  15. Gasifier
    Here is what I just did. I thought about if the cap to the gas is off and everything is drained out, if I push the primer bulb it should force the oil back into the gas tank. So I pushed it several times and sure enough the bulb is now empty. I will let it sit upside down for a while and let drain more now. Time to go cutting!:saw::saw:
    papadave, concretegrazer and pappy88 like this.
  16. man of stihl
    man of stihl
    NW PA
    Yep agree with guys above. Just flush it and it will be fine.
    Gasifier and pappy88 like this.
  17. man of stihl
    man of stihl
    NW PA
    It might smoke a bit when you first start it.
  18. Gasifier
    I use to smoke a little when I first got started too. :picard:Been over 10 years since I quit smoking. Might be 11 now. Can't remember chit. (C.R.S.) :D
  19. Stinny
    I think that CRS is pretty big club, Gas... :whistle: Sorry you had a problem with the saw. I get squirrels in my saw all the time too... wait... what?
    basod, thewoodlands, milleo and 5 others like this.
  20. Gasifier
    I wondered why the primer bulb was hard to push. ? Then I took a little closer look :binoculars:and said to myself. "Self, that is some pretty dark looking gas in there. Uh. Oh." :picard:
