Help -weird mechanical, plastic smell from my insert
Discussion in 'Modern EPA Stoves and Fireplaces' started by Bill Lion, Oct 11, 2015.
  1. Bill Lion
    Bill Lion
    Greater Hartford, CT
    Hey all,
    I used to be quite active in the wood forums, but have been off for awhile. I'm having an issue I could really use some help with.
    I have an older Avalon insert that I don't really know the model of as it came with the house I bought 4 years ago; I have attached a pic.
    I had the liner professionally replaced 2 years ago and have had the insert cleaned, serviced regularly, but the issue is the insert now produces a mechanical, almost plastic smell when I burn. It fills my whole living room and my family can't stand it. I've called 2 different chimney companies and nobody seems to have a satisfactory solution.
    Help! Does anybody know what might be causing this, and more importantly, what I can do about it?!? Thanks!
  2. Gark
    Gark
    SW Michigan
    Did this happen for your first or second burn of the season, after sitting idle all summer?
    The reason I ask is that all 3 stoves we've had stunk like burning dust (even after cleaning & dusting first) for the first couple of burns of the season. I sort of recall some others having the same happen. With ours, it always cleared up after 2-3 burns.
    Bill Lion and Backwoods Savage like this.
  3. Backwoods Savage
    This is a new one on me except for the dust like Gark mentioned. Have you checked the liner for birds? Animals?
    Bill Lion likes this.
  4. Norky
    Norky
    Do you have stink bugs in your area? They could create an awful smell if they got in the blower chamber. There was a bunch of them crawling around inside the stove on our first burn.
  5. HDRock
    I'd be checkin the blower out
  6. FastDonzi
    FastDonzi
    East TN
    During the learning curve on my old stove (Buck 27000) we had accidently left the draft doors open too long and got too Hot, Then Every time we burned we would get a smell, it was where the fan motor had been over heated and it would blow this plastic/burnt epoxy smell into the room. I replaced the motor and didn't have the smell again..
  7. Backwoods Savage
    Please let us know when you find out for sure what is causing this.
    Bill Lion and Norky like this.
  8. Bill Lion
    Bill Lion
    Unfortunately, it persisted past a few burns; seems to be an ongoing issue.
  9. Bill Lion
    Bill Lion
    The sweep did, nothing found
  10. HDRock
    Because you have an insert, I am assuming that you use your blower, most or all of the time, is that right?
    CleanFire and Bill Lion like this.
  11. Bill Lion
    Bill Lion
    Thanks. Sorry, it took me so long to reply. Been recovering from a little unexpected surgery this week. A couple things that made most sense to me here is the fan and/or fan motor. Def need to check that out I think.
    I appreciate everyone's ideas and will let you know the outcome. If anyone can think of anything else, let me know!
  12. Bill Lion
    Bill Lion
    Yes, that's correct -almost all the time
    HDRock likes this.
  13. HDRock
    Hope you have a speedy recovery from your surgery there :)
    Bill Lion and CleanFire like this.
  14. GranpaJohn
    GranpaJohn
    Central Maryland
    bit of a long shot, but the latch on my insert needs lubrication several times each season, and I once changed to a teflon bike chain lube, which lubricated fine, (i though I was so smart). But, there was a definite burning smell, and I finally realized it was the teflon lube. (After the second application, of course). Switched back to ordinary oil...smell gone.
    Like I said; long shot.
    P.S. "unexpected surgery" can't be too good.
  15. FastDonzi
    FastDonzi
    East TN
    Does your glass stay that clean while burning??
  16. CleanFire
    CleanFire
    And the insulation jacket on -all- the wiring inside the stove, needs a complete, thorough, visual inspection, just to be safe Bill. Sending good thoughts your way for a speedy recovery.
  17. Bill Lion
    Bill Lion
    Guys, thanks so much for the tips.
    And thanks for the thoughts, prayers for recovery I appreciate it. A simple procedure against all odds went wrong and required surgery and now a week recovery. Stinks temporarily, but I should be golden soon. Certainly gives me greater empathy for those with long term illness, injury and pain. Must be much tough without seeing recovery on the near horizon.
    HDRock likes this.
  18. Backwoods Savage
    Glad it is only a week Bill. Crap, mine has been almost 4 months already.
  19. Bill Lion
    Bill Lion
    So sorry to hear man; hoping and praying you're well soon
  20. Bill Lion
    Bill Lion
    It does most of the time. Sometimes it gets a film. Not black but still a film
    Backwoods Savage and FastDonzi like this.
