  1. will711
    will711
    Pocono Mts.
    Doing the same thing here :handshake: :whistle:
    IHATEPROPANE, ivanhoe, gbreda and 2 others like this.
  2. wildwest
    I have the sponge one over the motor thing, and a paperbag
    ivanhoe, ttdberg and slvrblkk like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Unless the paper ones are for drywall or fine dust, you're probably going to have dust escaping the vac.
    ivanhoe, will711, gbreda and 2 others like this.
  4. wildwest
    :handshake:
  5. wildwest
    LBT done! Was not eventful, not alot blew out after the first 10 seconds, ran clear after a couple minutes. It was white/grayish ash.
    CleanFire, ivanhoe, bogieb and 4 others like this.
  6. gbreda
    gbreda
    NH
    Yeah. says medium filtration. You need the ones specifically for drywall and fine filtration
    These are the ones I use and get at WalMart. They are not cheap but they work.
    Yours is for a 4-5 gallon vac...the ones I listed are for larger vacs. Just make sure it says Fine/Drywall and you should be good.
    ShopVac # 90672
    Shop Vac Style I High Efficiency 90672 Dry Wall Vacuum Bags for 10-14 Gallon Vacuums - 2 Pack
  7. wildwest
    ivanhoe likes this.
  8. imacman
    imacman
    Denver, NC
    Yep, what he said. Only bags made for drywall dust and/or ash will work.
    ivanhoe, slvrblkk and wildwest like this.
  9. smoke show
    smoke show
    Pittsfield, Wi
    My turn to cook.
  10. wildwest
    Ooops, just made an order last night from walmart for other stuff. I will grab the drywall ones next order :)
    The ones gbreda posted come in small/med/large. Small is for 5-8 gal vacs. Suppose I could use those in my 4.5 gal vac?
    gbreda, ivanhoe and imacman like this.
  11. wildwest
    currently reading about spark buckets somewhere else.......
    ivanhoe, imacman and slvrblkk like this.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    CleanFire, ivanhoe, will711 and 4 others like this.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    Hmmm....I would azz-ume :D
  14. wildwest
    Next time you iron a shirt and go to work it will be like the Seinfeld calzone.
    eatonpcat, CleanFire, ivanhoe and 4 others like this.
  15. imacman
    imacman
    Denver, NC
    YAY! Another Seinfeld fan:
    ivanhoe, will711, smoke show and 2 others like this.
  16. smoke show
    smoke show
    Pittsfield, Wi
    No seriously.
    gbreda, eatonpcat, CleanFire and 7 others like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    White smoothie and T-bones?
    eatonpcat, CleanFire, ivanhoe and 5 others like this.
  18. imacman
    imacman
    Denver, NC
    ivanhoe, wildwest, savemoney and 3 others like this.
  19. Spock
    Spock
    MA
    ivanhoe, wildwest, imacman and 2 others like this.
  20. smoke show
    smoke show
    Pittsfield, Wi
    Believe it or not, they were porterhouse.
    gbreda, ivanhoe, will711 and 5 others like this.
