Who's firing up the stove tonight ?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Russell, Oct 1, 2015.
  1. will711
    will711
    Pocono Mts.
    Toss in some Brats with peppers and onions who needs nuclear bombs :whistle:
    slvrblkk, imacman, smoke show and 5 others like this.
  2. jtakeman
    Ewwww! :faint:
  3. IHATEPROPANE
    IHATEPROPANE
    If it were me I would run it on the lowest setting that keeps you comfortable. The stove should cycle less often.
  4. will711
    will711
    Pocono Mts.
    Mine is on now taking the damp chill out had thunder boomers come through earlier .
    slvrblkk, ttdberg, imacman and 3 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    Mine too. I have burned two bags so far this year:hair:
    slvrblkk, imacman, CleanFire and 2 others like this.
  6. ttdberg
    ttdberg Pellet Pig
    CT
    Bag 3 in the hoppa now...
  7. will711
    will711
    Pocono Mts.
    About 1.5 bags here haven't fired it since last weekend .
  8. IHATEPROPANE
    IHATEPROPANE
    I have been burning for an hour or two almost every night since I started. A little more on the weekends. I love that the EP has a real low setting. The West Point would have gone on/off a hundred times already this year.
  9. will711
    will711
    Pocono Mts.
    Smoothie 9 in my hoppa :cheers:
    slvrblkk, imacman, smoke show and 4 others like this.
  10. jtakeman
    I'm at 2 bags............ One more ripped bag of sets to go in and back to MWP.
    Took a temp on the sets, Yea they are still HOT!!! :MM:
    slvrblkk, imacman, ttdberg and 5 others like this.
  11. Russell
    Russell
    South Coast , Massachusetts
    Well I ran her on high for 3 1/2 hrs . and that pretty much burned off the smell . As far as what setting to use this time of year I use Med . my stove is at the bottom of the stairs . Also same here a little at night and early am .
    slvrblkk, imacman, ttdberg and 6 others like this.
  12. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    I just turned the central air on:p
  13. CleanFire
    CleanFire
    Just opened bag 5 here - we're tired of hearing the FHA furnace cycle already, and it's October.
    Hey, Thanks for that! Still have to pull the window air conditioners, Thanks for the reminder.. :p
    Russell, slvrblkk, will711 and 4 others like this.
  14. CleanFire
    CleanFire
    That's a nice looking stove! What model Enviro, please?
    On the stove here we run at middle setting to start / until the stove is heat soaked, then stove automatically backs down to 'modulate' mode / lowest setting (1.0 lb/hr) until the thermoprobe calls for heat again.
    Point being we've found here it is much easier to run at lowest setting, after getting the stove up to temp. / heat-soaked, before backing down to low setting.
  15. krooser
    krooser
    Waupaca, WI
    My shop is a toasty 75F tonite. My house stove is still waiting a repaint...
  16. kdp7462
    kdp7462
    maine
    Hi CleanFire,
    The stove is an Enviro M55C. We had it installed at the end of August so still playing with settings and such. It hasn't been cold enough to run it too long, but I will keep it at the lower settings for now.
    I like the on/off as well as high/low option, so will likely switch to high/low when we get deeper into October.
  17. will711
    will711
    Pocono Mts.
    I'm burning tonite , My Honey came home and said it was cold and damp in the house [68*] ,Fire it up :thumbs: all good now :fire:
  18. Russell
    Russell
    Same here I just turned mine on low . I guess this weekend highs 50 lows 40 maybe 30 ish .:thumbs:
  19. will711
    will711
    Pocono Mts.
    Prolly get our 1st frost this weekend ,stove will be running
  20. jtakeman
    We've been turning the stove on just before bed and off again just before we go to work so my son(who might forget to turn off the stove) can open the widows and slider once he gets home from school. Its only fired on the chilly mornings and for the most part has been off for the last week or so. That is as long as dad turns it on before bed............ Funny I don't have a problem remembering to turn it off before I head off to work................... :emb: Good thing it hasn't been too chilly on the oopsie mornings I forgot!! :pain:
    It will be on for sure Thursday AM if it gets as low as they predict and surely this weekend. :shiver:
