IS or PH dilemma
Discussion in 'Modern EPA Stoves and Fireplaces' started by ESVA Fireview 201, Oct 8, 2015.
  1. Backwoods Savage
    Well congratulations! Please keep in touch and let us know about your install and also your experiences with the stove. I don't think you'll have problems getting used to the stove because you've had experience with the Fireview.
    papadave likes this.
  2. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    Oh.... horse hockey! The ash pan is the best thing that ever happened to wood burning stoves. Saves all the shoveling. :p
    I told him, I did! :rofl: :lol:;):doh:
    jo191145 and Backwoods Savage like this.
  3. Backwoods Savage
    The Fireview is the first stove we've owned (and we've owned several) that is without the ash pan. We find it to be no problem at all. Actually, we like it.
  4. ChuckinMichigan
    The real funny part? I don't even own a stove! (yet!) and I'm all arguing about ash pans! :rofl: :lol::hair::doh:
    concretegrazer likes this.
  5. HarvestMan
    HarvestMan
    I like the simplicity of not having an ash pan; one less place for air leaks (my old Hearthstone had this problem). As far as looks go, the height of the ash pan area being larger than either the soapstone panels above or below the glass draws my attention for some reason; I just prefer the stove without one. Also on the topic of looks, there seems to be two kinds of short stove legs - I like the narrow ones, but not the wider ones.
    Images from WS Owner Photos section
    [​IMG][​IMG]
    papadave and Backwoods Savage like this.
  6. fire_man
    fire_man
    North East MA
    Dennis
    I agree it looks better without the ash pan. But you really don't notice the difference after while, and after owning a WS ash pan system, you will wonder why you ever did without it.
    I was worried about the extra gaskets but took a leap of faith on WS Engineering. It's well designed, simple and looks bullet proof.
  7. ESVA Fireview 201
    ESVA Fireview 201
    Accomac,VA
    The only reason we picked the short legs was due to our lintel height. I think it looks cool with the short legs and we are used to no ash pan with our FV. One less gasket for me to worry about!
  8. bushpilot
    bushpilot
    Eastern Washington
    Well put your big-boy pants on and go get one!
    Greg
    ChuckinMichigan likes this.
  9. ChuckinMichigan
    Wish I could. :(
  10. Backwoods Savage
    ESVA, I had asked Brian to answer this post. He has not been on the forum much lately due to work and illness. He did tell me he saw the thread but when he saw you are ready to buy, he just passed on answering. Just thought you'd like to know.
  11. ESVA Fireview 201
    ESVA Fireview 201
    Accomac,VA
    Thanks for your reply... I would love to have heard his two cents on it since he previously owned a FV and could give his opinion on the feel of the heat from the two stoves.
    BrianK and wildwest like this.
  12. Backwoods Savage
    Believe me ESVA, he will say the very same thing we have said. The heat from soapstone is a soft heat. Usually you can stand right next to the stove and not feel like you are going to be burned. Stand 15' away and you still feel warm. The radiant heat is super! Now when a home or cabin is really cold, like no heat for days and it is cold, you will feel the heat faster from a steel or cast stove but overall, the house will heat up in about the same amount of time and there usually aren't any cold spots with soapstone heat.
    In defense of Brian, he has had some very serious problems as of late and we understand why he has not been on the forum much. In addition, being a doctor plus other interests, he is a very busy man. Also I might add a very nice man indeed. I was fortunate to have met him 2 years ago when he picked up his stove in Washington DC. We were there for the stove competition, which Woodstock won!
    Brian's stove at DC.
    Tom Morrissey, the Ornery one, yours truly, and Brian.
  13. burndatwood
    burndatwood
    VT
    I faced the same dilemma last year. So I decided to get one of each!
    I'll agree with those who say you can't go wrong with either stove. My wife likes the Progress because of the same reasons you mentioned, especially the side loading door and the classic look. We too have an old Victorian home, and the looks of the PH match the house. You'll be 100% satisfied.
    Needless to say, there will be those who want to see pics...
  14. BrianK
    BrianK
    West central PA
    Thanks Dennis. I can't add much to what has already been said. We had a Fireview, then the Beta IS and now the production IS. The soapstone is definitely a softer heat. The steel wrapped IS, even with its soapstone firebox, acts more like a steel stove IMO.
    The Fireview with its 2.0 cu ft firebox gives off great heat. With the side loading, its runs cleaner too. The IS with its 3.2 cu ft firebox and hybrid system can give off a tremendous amount of heat in a shorter time. With that big front door, its a bit dirtier to run than the side loader in our experience.
    On the other hand, if money had been no object, we would have a PH because the whole family liked the looks of soapstone a lot more. We have no regrets about the function of the IS. Its easy to use and fulfills its purpose flawlessly.
  15. BrianK
    BrianK
    West central PA
    Great memories, thanks Dennis!
  16. JA600L
    JA600L
    Lancaster, Pa
    I'm curious, how do the soapstone stoves do as far as heat movement through a house? For example, I heat from my basement, to the upper level. The steel stoves I have get into a convective loop and pull the cold air down. Then the hot air replaces the cold. Does the radiant soapstone act similar?
  17. ESVA Fireview 201
    ESVA Fireview 201
    Accomac,VA
    Brian,
    Thanks for taking the time to respond. We really like the soapstone heat from our current FV and the side loading too. We can't wait to get out new PH and the extra warmth it will bring. Thanks again for your two cents.
    Tony
    BrianK, Backwoods Savage and Brad38 like this.
  18. Backwoods Savage
    It should but most folks do not have good luck trying to heat from a basement. But I can say as far as moving heat through a house on the level, they work super great.
    Sometimes folks will blow a fan down the stairway to try helping move the warm air up into the upper levels.
    Well Seasoned likes this.
  19. JA600L
    JA600L
    Lancaster, Pa
    I insulated the basement first. That's the ticket.
  20. Oldhippie
    Oldhippie
    Ashby Ma
    Heat does rise... but in a basement, if it isn't insulated the concrete basement walls will suck up a lot of heat, making it a very inefficient place to put your primary heat source. But, for many it's only place so that makes it the best place.
    I've got one in our basement/laundry/family room too, and it gets used when it gets really cold out. Extra btus never hurt anyone. :)
