NC30.... Craigslist Score
Discussion in 'Modern EPA Stoves and Fireplaces' started by Chvymn99, Oct 5, 2013.
  1. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Push your Fiber Board together. You have a gap between the two.
    Chvymn99 and raybonz like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Wow you have a good eye! I don't even see the fiber board in that pic..
    Chvymn99 and fox9988 like this.
  3. Chvymn99
    Ok, Thank you. I'll check into it as soon as it cools off a bit.
  4. blwncrewchief
    blwncrewchief
    NorthCentral, IN
    Look right on top of the secondary tube. The baffle boards are the two gray pieces you see right on top of the tube and if you look close right in the center you can see a 1/4-1/2" gap between them.
  5. fox9988
    fox9988
    NW Arkansas 72717
    That's kinda a pet peeve of his:p Just as well get max efficiency.
    BrowningBAR, raybonz and Chvymn99 like this.
  6. papadave
    The force is strong with BBar.:thumbs:
    raybonz and fox9988 like this.
