Chimney cleaning
Discussion in 'Modern EPA Stoves and Fireplaces' started by mattjm1017, Dec 21, 2013.
Top down or Bottom up and why?
  1. Top Down
    55.0%
  2. Bottom up
    35.0%
  3. Doesnt matter just clean it!!
    10.0%
  1. mattjm1017
    mattjm1017
    Its about time for a mid season cleaning and I realized I haven't seen any threads on top down or bottom up. Whats yalls opinion is one better than the other or does it matter? I am planning to do bottom up because I don't have a ladder tall enough to safely get to the top of my chimney, but I do have concerns that I'm not getting the top very clean. I had the chimney cleaned at the begging of the season and the sweep said it looked good so I must be doing something right. Anyway lets have it I want everyone's opinion of this.
  2. savemoney
  3. concretegrazer
    concretegrazer
    Southwest MO
    I clean from the top down because its what's easiest for me.
    mattjm1017 likes this.
  4. milleo
    milleo
    Bottom up and I can do it from the ground....So very easy and safe for me, no ladders...:)
    mattjm1017 and thewoodlands like this.
  5. Well Seasoned
    I have an almost flat roof, and although I'm at the top of a 12 ft ladder, it is the most ideal way to do it. Having a telescoping stove pipe, it is not the easiest way to clean it bottom up.
  6. thewoodlands
    thewoodlands
    We can do the cleaning from the bottom up, I always check the screen with binoculars, so far it's always stayed open.
    mattjm1017 and NortheastAl like this.
  7. Backwoods Savage
    We do it both ways. Does that make us ambidextrous?
  8. rottiman
    ...................multi-talented @ the minimum! LOL
    mattjm1017, Chvymn99 and NortheastAl like this.
  9. Backwoods Savage
  10. DexterDay
    Top down, but it's the easiest way for me. Using a Lint eater and I have rods and a 6" steel brush.
    I take the top 3ft section off (includes cap) and the hole is just below waist height for me (perfect). I didn't need the last 3 ft section, but I had it and the 18' of vert outside makes the 30 draft nice :)
  11. Machria
    Machria
    Long Island, NY
    Bottom up, because you can't get onto my roof without a 45' ladder, which I ain't doing!
  12. Lumber-Jack
    Lumber-Jack
    I clean my chimney from the top down, but for obvious reasons I would never expect my grandmother to do it that way.
  13. blujacket
    blujacket
    Kettering, OH
    I pay a sweep to do mine in the Spring. Two man crew, one cleaning from bottom, the other from the top.
    mattjm1017 and Mitch Newton like this.
  14. Locust Post
    I do mine from the top because I have an insert and it is the easiest way. Plus I really never gave it much thought of doing it any other way until I started posting.
  15. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Top Down. Low pitch roof with a skylight to get easy access.
    1.) I can re-position the TV antennae up there if needed.
    2.) Sooteater scares the crap out of the cats and kids when I run it down.
    3.) No mess inside.
    4.)Neighbor sees me doing it and hopefully reminds him not to wait two years to get his done.
  16. fox9988
    fox9988
    NW Arkansas 72717
    You can open your skylight? I didn't know that was an option.
  17. fishingpol
    fishingpol
    I have Velux brand. The lifting arms at the crank end can be removed from the track in which they slide. Once out, at the hinge end there are two spring-loaded latches that hold the pivots that let the whole sash pop out.
    Six foot step ladder up and I'm out. It is great access for shoveling the roof off.
  18. Chvymn99
    Bottom up....Easier (angle of roof + height = not for me) and soot eater...
  19. mattjm1017
    mattjm1017
    So from what Ive read here it doesnt matter just clean it. I was just curious if there were any pros and cons of going one way or the other. Ill stick with bottom up even though its a pain in the azz its not as bad or dangerous as going to the top.
  20. sherwood
    sherwood
    Hey, Matt , let us know if you get anything when you sweep. A Fireview done in the Autumn will likely have very minimal results now...maybe a cup or so ?
    Probably once you sweep now, you'll feel comfortable waiting until Spring for the next sweep. Comfort is a great thing, so sweep away.
