  1. DaveGunter
    DaveGunter
    basod, papadave, unclefess and 3 others like this.
  2. Stinny
    Just glad I didn't have to shovel it off every time I worked on it... :whistle:
    Here's what it used to look like... in the winter...
    basod, papadave, rottiman and 4 others like this.
  3. Horkn
    You can probably just get a new rod, the rest of the cylinder is most certainly OK.
    If you were closer, where I work does everything hydraulic related, and we could take care of your friends.
  4. Horkn
    You mean it's not a game of piƱata basketball?
    Getting old sucks.
    papadave and wildwest like this.
  5. Horkn
    Stinny and wildwest like this.
  6. Stinny
    2 Behr slate gray stains. Deck has the grit in it.
  7. Woodwidow
    Nice work. it looks great.
    papadave, unclefess, Horkn and 3 others like this.
  8. wildwest
    x2!
    papadave, Horkn and Stinny like this.
  9. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    That'd make a heckuva head for a "weedeeder!" :jaw::yes:
    Horkn and wildwest like this.
  10. ChuckinMichigan
    Oof! :doh:
    Not good. :(o_O:jaw:
  11. ChuckinMichigan
    I'm telling ya.... goes from bad to "Don't look ethel!" in a half a page! :rofl: :lol:
    Woodwidow, papadave, Chvymn99 and 3 others like this.
  12. wildwest
    I appreciate the well needed chuckles here every day.
  13. unclefess
    unclefess Guest
  14. Chvymn99
    Awwwww.... Last Day of Summer .... Onto our favorite times of the year for many of us...:campfire::axe::stacke::coldfire::fire::MM::saw:
    Stinny, Horkn, wildwest and 4 others like this.
  15. rottiman
    X 3
    Canadian border VT and wildwest like this.
  16. cnice_37
    cnice_37
    Even better, I have been advised it may be able to be bent back. I gave him the name of the shop to take it to. The rod is $400+ alone from Kubota. $530 for full assembly. Plating on the rod looks fine, so I'm hoping its not as expen$ive as it looks.
    We'll see. I was going to go all out measuring to find a generic swap in, as I'm sure that orange paint costs alot. Hopefully the repair route works out, if not I'll help them find a replacement.
    Horkn, basod and wildwest like this.
  17. rottiman
    Doubt that you will find it to be totally straight if they try to bend it back................Did you try to locate a hydraulic service shop in your area vs. going back to Kubota. Their parts carry primo pricing. An independent hydraulic shop should be more reasonable.................just sayin'
    Horkn, basod, wildwest and 1 other person like this.
  18. cnice_37
    cnice_37
    My uncle saw the picture and recommended a local shop. I am just the middle man, so I gave them the name and told them what he told me. Plating looks good, so according to him there's a good chance it can be fixed. In the event it can't, then they are at the local hydraulic shop so should be able to find a direct replacement.
    I was able to look up the Kubota pricing online as I don't have dimensions yet on everything else. I like sticker shock, as I know usually there are better alternatives so plan for $500+ and hope to skate for less, ya know?
    Horkn, basod, rottiman and 2 others like this.
  19. lukem
    He should be able to get it pressed back straight "enough". Doesn't need to be perfect...just needs to go into the cylinder and not leak. If that doesn't work, a good shop should be able to swap in a new rod for a LOT less that 500 bones.
    Horkn, rottiman, wildwest and 3 others like this.
  20. lukem
    Upper 40's in the AM, 80 in the afternoon.
    Horkn, wildwest and papadave like this.
