Trailer Project
Discussion in 'Chainsaws and Power Equipment' started by Certified106, Sep 18, 2015.
  1. Certified106
    Certified106
    In The Hills
    I finally decided I was going to do some work to my 16 foot trailer that I picked up 4 years ago off Craigslist for a steal. So far it has been good to me and when I bought it it had new trailer brakes and bearings as well as a new break away box. I didn't think the boards would last as long as they have but the time came to replace them so I started on it tonight.
    I cut the boards off with the best tool known to man and got the frame washed and scrubbed down. Tomorrow I hope to prep the frame under the floor then paint it. After that I am going to put down a new pressure treated deck on it and build some side rails to aid in firewood hauling.
    Everything still looks good and solid and nothing is bent or twisted so I am happy about that. Here area few pics to get started including some new wood for the bonfire.
    20150918_180759.jpg 20150918_182706.jpg 20150918_183116.jpg 20150918_183123.jpg
  2. Gasifier
    Nice work certified! Looks good.
  3. Stinny
    Looks good so far. She'll be brand spankin when you get'r done. Good size trailer frame... :yes:
    Chvymn99, HDRock, Shawn Curry and 2 others like this.
  4. WVhunter
    WVhunter
    Mountains of WV
    Looking good, post pics of her when you get it done. :yes:
  5. Certified106
    Certified106
    In The Hills
    Quick question, the trailer is 78" wide where the decking will be. I was planning on going with 2x12x16 boards since I will only have to take 2" off the last board. If I go with those boards it is about $130 for new decking.
    The other option is to go with something like a that isn't quite as wide but end up with a smaller last board.
    Is there any other reason to go with smaller boards width wise?
    Stinny likes this.
  6. Stinny
    Wider planks. Should be good and rugged.
    MasterMech likes this.
  7. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I would not use 12" boards as my experience is that wider boards are more prone to splitting. When I rebuilt my trailer 7-8 years went with 2x8's on the outside and 2 2x6's in the middle. No ripping was required.
  8. HDRock
    Looks like a naked trailer :DThe wider the board the more it will cup, , crack, split, twist, crook and wang, expecially treated wood
  9. Stinny
    Yep, gotta lock down your deck or it'll take off on ya. Pressure treated sure does crack and split over time. I screw the planks down with lots of these deck screws. Fast and easy... drill pilot hole and drive the screw. Cuts it's own thread going thru the steel. 3 across a 12" plank, on every rail.
  10. redneckdan
    redneckdan
    Northern Minnesota
    Add some angle as a railing about 12" up and you will be amazed how much it will stiffen up that trailer. That whole Ix^4 + A*d^2 thing....
  11. MasterMech
    Fixed. ;). And agreed! Even a short rail does wonders.
    Fanatical1, Certified106 and Stinny like this.
  12. redneckdan
    redneckdan
    Northern Minnesota
    Yup tube is better than angle, most don't seem to want to spring for the extra cost.
  13. Certified106
    Certified106
    In The Hills
    I get that and I had thought about it but I haul stuff that at times needs to hang over the side a bit and it is nice to be able to slide pallets straight on the bed from the side which is why I was thinking removable sideboards.
  14. Certified106
    Certified106
    In The Hills
    I got the underside of the frame wire brushed with an angle grinder yesterday. It took about three hours and just about destroyed my back and maybe my lungs lol. I even wore a paper mask and still managed to breathe the crap.
    After I got done I had to go out to my parents and now for 4 hours so nothing else got done. If my back holds out I would like to start painting the underside today.
    Moparmyway, papadave, Stinny and 7 others like this.
  15. Oldman47
    Oldman47
    Illinois
    If you don't wear your watch the contrast won't be that bad.
  16. Certified106
    Certified106
    In The Hills
    Got the whole underside of the trailer frame painted. I even had some help even though it probably added some time lol. She had fun though.
    I need to go figure out what boards I am going to go with so I can get them purchased.
    ID1, Moparmyway, papadave and 7 others like this.
  17. Black Dog Chainsaw
    Black Dog Chainsaw
    Central Iowa
  18. Certified106
    Certified106
    In The Hills
    So I spent a bunch of time trying to figure out what and how much lumber to buy. I ended up going with 2 2x8x16's and 11 2x6x16's. I figured that when they were all placed on the deck and pushed tight together it would give 1.25" of gap on one side and allow me to space them all out to between 1/16" and 1/8". I bought the lumber and started on the deck tonight and figured this wouldn't take more than an hour or two (lol yeah right):rofl: :lol:
    Right off the bat I realized all the boards are soaking wet and swelled up which meant that none of them want to fit under the lip on the back side of the trailer. I then had to cut each board to 16 feet and sand a slight taper into the board so that it would slide in to the lip on the trailer. Everything was going ok until I got to the last two boards and realized they aren't going to fit :doh:.
    Turns out all the 2x6's (which should be 5.5") are actually closer to 5.75" so when you add up all the boards I lost right at close to 2.5". I now have a final opening that is roughly 3.5' wide and an extra 2x6 that doesn't fit. I now have 2 options go get a 2x4 which would drop in with a bit of coaxing or remove another 2x6 and drop a 2x10 in. I am leaning towards the 2x4 unless someone talks me out of it as I can split the 2x6's and put 5 on one side and 5 on the other and drop the 2x4 right in the center to keep everything all nice and symmetrical (yes I can be a bit OCD).
  19. cnice_37
    cnice_37
    Rip the 2'x6' and git 'er dun
    HDRock likes this.
  20. Certified106
    Certified106
    In The Hills
    That though crossed my mind more than once but the tight wad in me says I can save $5 by returning it :whistle::rofl: :lol:
    although it's probably not worth my time........
    clemsonfor, papadave and cnice_37 like this.
