just a pic of the wood
Discussion in 'The Wood Pile' started by Woodrat1276, Sep 17, 2015.
  1. Woodrat1276
    Woodrat1276
    Ky
    image.jpg image.jpg I need to get going if it ever cools down cleaning up the wood pile
    Then I can start bringing some more in
    Bert, J1m, HarvestMan and 17 others like this.
  2. ID1
    ID1
    N.E. Ohio
    NICE! Things look greener there !
  3. Gark
    Gark
    SW Michigan
    Wowsa, that's TONS o f wood. You've been BUSY. How long will all that in the pic's last you? Good job!
    Bert and unclefess like this.
  4. HDRock
    Awesome pile a wood there rat :thumbs: :stacke::stacke::stacke::stacke:
  5. bogydave
    Nice stacks :yes:
    Millions of BTUs there!
  6. Backwoods Savage
    Very nice indeed. Do you plan on top covering the wood?
  7. Woodrat1276
    Woodrat1276
    Ky
    Thought about it but I'll have that amount and more coming in this fall winter Just to much to try and cover
    However there is a slant where the wood is sitting and a constant breeze as well with unless it's raining or cloudy 8 plus hours af sun hitting it
  8. Backwoods Savage
    Woodrat, I know many don't cover and get along okay and I have no problem with that. However, in our experiment, we found that although the wood will dry fine and will burn fine, if you top cover, the wood will be much better and you'll get much more heat from it thereby saving you some hard labor. I know it was an eye opener for me the last time we experimented with it.
  9. Woodrat1276
    Woodrat1276
    Ky
    not really sure to be honest I hope to use very little if any this year
    It's stacked in the order it was cut and split so wood on the far end is over a year of seasoning
    It's all ash and some but little maple that's stacked The loose stiff and logs are maple and locust. And there is about Ten rounds of walnut sitting there too
  10. Woodrat1276
    Woodrat1276
    Ky
    I did attempt to top cover one row last year I used some roofing paper and it seemed like I just could not keep it on there
    I may try to do it again im not against top covering I like you believe it has its benefits I just haven't quite figured out how I'm going to do it lol
  11. Backwoods Savage
  12. Woodrat1276
    Woodrat1276
    Ky
    Bert, Gark, WVhunter and 1 other person like this.
  13. Backwoods Savage
    Sure you can Woodrat. You can even do better, I'd bet.
    Bert, Shawn Curry, WVhunter and 2 others like this.
  14. Woodrat1276
    Woodrat1276
    Ky
    I do however make a attempt to put bark up on the lady top three rows I'm going to revisit the top covering this year I think
  15. Woodrat1276
    Woodrat1276
    Ky
    You cant see in the pictures but I used a log on one end as a brace for the end of the stacks when the log ran out I used a tower to brace the end with and it worked out well
    I swear and I don't know how they have stayed standing but my stacks give the tower of Pisa a run for its money lol
  16. NYCountry
    NYCountry
    Mohegan Lake NY
    Nice looking stacks. Nice view also..how many years ahead are you? How many cords did you go thru last winter
    Bert, Shawn Curry and WVhunter like this.
  17. Woodrat1276
    Woodrat1276
    Ky
    I usually do my amounts in truck loads and honestly I always plan 24 truck loads regardless if I use them or not
    If I use them then I know I need that amount back if I don't then it's more for next season and another 24 is added on
    Bert, Shawn Curry, WVhunter and 3 others like this.
  18. Backwoods Savage
    We used to count trailer loads like that and by habit, still do.
  19. Locust Post
    Lookin good Rat.....don't know what size truck you have but an 8ft bed stacked in is close to 1/2 cord.
  20. Shawn Curry
    Shawn Curry
    Western NY
    I measure wood amounts by trailer load as well. I've gotten pretty good at guesstimating how much I've got on there. Mine will hold around 1/3 cord if it's stacked roughly 2' high.
    That's quite the concrete pad - did there used to be a building there? Seems like it would make a great place for a shed! ;) Nice sunny spot too! :yes: That pic was looking towards the north right?
    Bert and Backwoods Savage like this.
