Roll Call: Who's Cleaned Their Chimney?
Discussion in 'The Wood Pile' started by Jack Straw, Sep 15, 2015.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I cleaned my father's yesterday and mine today. I like to clean mine just before I start burning to make sure everything looks good. In the stove I found 2 steel brackets that hold the fire brick bent (above the air tubes), so I'll get some from my local hearth shop.
  2. Elderthewelder
    Elderthewelder
    Washington State
    did mine last week, I do it every year about this time frame along with a complete cleaning of insert. Have a few cracked fire bricks / other than that all good to go
    HDRock, basod, gboutdoors and 6 others like this.
  3. Gasifier
    Not me yet. That's on the list. Now. Was that number 9 or 10 or........:confused:
    HDRock, basod, unclefess and 7 others like this.
  4. markr
    markr
    ohio
    Cleaned mine at end of burning in the spring. Will re inspect before first fire.
    HDRock, gboutdoors, Chvymn99 and 4 others like this.
  5. Well Seasoned
    I'll be sweeping mine this weekend. My son started to pile up some of this season's supply in front of the shed for me to stack this weekend as well.
    HDRock, gboutdoors, Chvymn99 and 3 others like this.
  6. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Cleaned mine at the end of last season. Will still drop a rope down from the top to the clean out T to make sure nothing built a nest in it. Its blocked of with a towel from the T into the house so no worries there.
  7. WVhunter
    WVhunter
    Mountains of WV
    Cleaned stove and checked it last weekend, going to swab stove pipe this weekend. Should be good to go then. :yes:
    HDRock, gboutdoors, Chvymn99 and 2 others like this.
  8. wildwest
    Same here. We have two to clean.
  9. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Thanks for the reminder. Will be on the top of this weekends to do list.:)
  10. Chris F
    Chris F
    Micksburg, Ontario
    Same here. I like to clean it all up before the heat of summer sets in and it's one less thing to do this time of year.
    I keep telling you guys, I'm anal :D
    HDRock, gboutdoors, Gasifier and 3 others like this.
  11. capetownkg
    capetownkg
    southern, MD
    Had mine cleaned about a month ago. Went up today to measure how long of a liner I will need for it. Hoping to have it done and in by first week of october
    HDRock, basod, papadave and 3 others like this.
  12. Chvymn99
    Cleaned mine at the end of the year last year. Will inspect before first fire.
    HDRock likes this.
  13. Certified106
    Certified106
    In The Hills
    Just cleaned mine tonight. Had about half a coffee can of dry powder.
  14. thewoodlands
    thewoodlands
    I'll do ours this week.
  15. WoodovenAT
    WoodovenAT
    New Jersey
    Last year was my first season burning in an insert, I installed the 6" stainless liner with insulation. I just started looking for the right brush and rods to clean it with.. Do I need to disconnect the liner from the insert before I sweep it?
    HDRock and Jack Straw like this.
  16. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    A few weeks out for me. I'll do it at the first cool snap. I need a northwest wind to push the soot away from me when I am on the roof.
    HDRock, papadave, unclefess and 3 others like this.
  17. HarvestMan
    HarvestMan
    Southeastern Michigan
    Mine was cleaned in May when my Fireview was installed. My sweep did it; he admitted he didn't even like getting up that high (cap is 35 feet from the ground).
  18. jetjr
    jetjr
    Pa/Md line
    Wanted to do mine today, but did not get to it. Think I'll try to get it done tomorrow. Got a little bit to add to the baffle and a few cracked bricks and I think one missing.
  19. Horkn
    Mine is spotless. It will be getting a SS liner for some sort of epa efficient wood burning insert this season.
    I'm doing my research now.
    HDRock, papadave, Brad38 and 4 others like this.
  20. Elderthewelder
    Elderthewelder
    Washington State
    I have a insert with 6" liner as well, I simply remove all the firebricks and unbolt the baffles / secondary tubes and remove them. Close the door tight and get on the roof and run a 6" poly brush up and down the liner. Let dust settle / open door and scoop out the mess / vacuum out fine stuff with ash vac if you have one
