I'm gonna need a bigger saw
Discussion in 'The Wood Pile' started by MissouriFrontier, Sep 12, 2015.
  1. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    this is my 362 carrying a 25 inch bar.. Looks a little under sized no?
    Huntindog1, Gark, Drvn4wood and 10 others like this.
  2. Jon1270
    Jon1270
    Pittsburgh, PA
    Just think of yourself as a well-equipped termite.
    Gark, Smokinpiney, HDRock and 6 others like this.
  3. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Anyone have any advice on breaking this thing up with that saw? Is it doable?
  4. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Man that is one big tree, what species is it?
    Maybe noodle vertically down the tree and then cut horizontally to break it off piece by piece? Sorry never really dealt with anything bigger than 20" or so.
    papadave and MissouriFrontier like this.
  5. thewoodlands
    thewoodlands
    I would start cutting from the "gooder" side so the tip of your bar ends up in the rotted part.
    Or if starting to cut from the rotted side works best, do that.
    When I started cutting (the 310 was my first saw) I had a tree down that was bigger than the bar could cut from one side, I just cut from both sides.
  6. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Is his bar going to reach from both sides, from the pic it looks like it might fall a bit short.
  7. thewoodlands
    thewoodlands
    I was thinking it would fall in the rotted section.
  8. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Th
    This is true, looks like it'd fall about dead center in the rotted out section.
    MissouriFrontier likes this.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    How good are you at swinging a maul sideways?
  10. concretegrazer
    concretegrazer
    Southwest MO
    Do this.
    Or buy one of these....
    Or something like this...
    Or buy that 046 that's in the classifieds.
    Ronaldo, Chvymn99, cnice_37 and 6 others like this.
  11. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Loving that Husqvarna.:thumbs:
  12. tamarack
    tamarack
    paulina oregon
    Just put a big bar on it, 28 or 32 will give you alot more reach. Ya i know a 32 inch bar on a 362 is a bit much, but if you put skip chain on it it will get er done.
  13. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    I run an 18 on my 61 and I'm nervous about that.o_O
  14. foragefarmer
    foragefarmer
    Central, Virginia
  15. HarvestMan
    HarvestMan
    Southeastern Michigan
    Pictures like that make he happy I am in the Firewood Cutters T-Ball league. Way out of my league ... good luck with that one!
  16. foragefarmer
    foragefarmer
    Central, Virginia
    Let's you make the big league scores.
    Chvymn99, concretegrazer and mdavlee like this.
  17. Backwoods Savage
    No problem. You can always cut a wedge out of the top and then finish the cut. As for the rot, no problem cutting there if you work both sides but you probably will find the rot does not go all the way up.
    Another way is to cut as much as you can and then sometimes you can break off the center (part you could not reach with the saw) using a few wedges.
  18. mdavlee
    mdavlee
    Noodle and then cut the pieces into quarters.
  19. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Red oak and yeah old and biiiiiig
    Chvymn99 likes this.
  20. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    I'd could make it happen.... Would rather not! Lol but yeah I could do that
