Woodshelter build
Discussion in 'The Wood Pile' started by mike bayerl, Sep 5, 2015.
  1. papadave
    The problem I have with the short overhangs is the dripping, then the splashback. Will the tarps help that?
    Shawn Curry likes this.
  2. Backwoods Savage
    Dave, can you get a few sheets of galvanized roofing or fiberglass or something similar and just put those along the bottom to stop the splashback?
  3. Backwoods Savage
    Mike, when you stack the wood in, you could also possibly stack it front to back rather than the long ways. Yes, it means more ends but perhaps easier to rotate the wood.
  4. jetjr
    jetjr
    Pa/Md line
    I run mine down to the ground and then add weight at the bottom.
  5. Backwoods Savage
    That doesn't sound good at all. Usually better to leave it up so air can continue to circulate. Even with the rubber roofing, there can be condensation.
  6. papadave
    I think he's talking about the overhang on his shed, Dennis.
    Correct me if I'm wrong jet.
  7. jetjr
    jetjr
    Pa/Md line
    Yes just the overhang on the shed. Still leave room for circulation.
  8. jetjr
    jetjr
    Pa/Md line
    Learned better than that from you.
  9. FastDonzi
    FastDonzi
    East TN
    if the ground has that much rock, drill it attach a cable to hold the shed down at each corner, then it wont blow over. I used that same clear roof on 1/2 my wood shed, the other 1/2 is metal so I don't have to work in the sun...mine is 24'x 31'
  10. Oldman47
    Oldman47
    Illinois
    For those cinder blocks just mix up some sacks of concrete and fill them. If you need an anchor, you could even put an anchor through the hollow centers before filling them with concrete and solve that problem too. Any anchor needs to be attached to the support posts, not just the cinder blocks.
  11. mike bayerl
    mike bayerl
    I like this idea. Simple and sweet. It is just a woodshed after all.
  12. Brad38
    Brad38
    S. Indiana
    Mobile home anchors in mine. It's not going anywhere. This could be an option if not too awful rocky.
  13. HDRock
    X2
  14. Frank and Beans
    Frank and Beans
    There are many kinds of splashback. They are all undesirable. Got to eliminate the splashback.
  15. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Only problem I see is that it is empty!:)
    Gary
  16. mike bayerl
    mike bayerl
    Well, I finally got the wood that was stacked there before back in place. About a cord of dry cherry, ash, black birch, red maple and tulip. That should get up started this Fall. Still haven't found any final anchor system.
  17. Shawn Curry
    Shawn Curry
    Western NY
    Just keep it full of wood. :D Look great! :yes:
    HDRock likes this.
  18. savemoney
    These might do it for you.
    Backwoods Savage and HDRock like this.
  19. mike bayerl
    mike bayerl
    Yeah. I think I can get away with something like that. Ground is really rocky, but I think I can make them work.
    HDRock likes this.
  20. savemoney
    I think that was on LOWES.
