Woodshelter build
Discussion in 'The Wood Pile' started by mike bayerl, Sep 5, 2015.
  1. mike bayerl
    mike bayerl
    Finished up tonight. 20' long x 55" wide, with 6' rear and 7.5 ft front. I should be able to get between 2.5 - 4 full cord in there depending on how high I want to stack and whether I stack 2 vs. 3 rows of 16-18" splits. Now I just have to move my dry wood under it.
  2. HDRock
    Good job , Lookin great :thumbs: that will be nice and keep the ol wood dry :stacke:
  3. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I love the clear roof. Of course it won't stay that way long.
  4. WVhunter
    WVhunter
    Mountains of WV
    Nice job, looks good! :yes:
    Shawn Curry, Eric VW and HDRock like this.
  5. Chvymn99
    Looks good and should do its job nicely there. Congratulations...:stacke::banana:
  6. Gasifier
    Alright! Good work Mike! Your stove will like that nicely seasoned wood!
    Shawn Curry, HDRock and Eric VW like this.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    Nice looking wood shed Mike. I like the clear roof and the length of it. My only question is updraft, is the shed anchored at all?
    Bubba, Brad38, Shawn Curry and 6 others like this.
  8. Elderthewelder
    Elderthewelder
    Washington State
    was thinking the same thing, appears to be just sitting on top those cinder blocks. some type of pier block would work better.
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm sure once the shed is filled the wind would have trouble catching the roof, but empty may have cause for concern.
  10. mike bayerl
    mike bayerl
    Perfect. That's what i was looking for but couldn't find at the local big box.
    As for the clear roof, I had some 12' long sheets lying around, so I cut them in half to 6'. They are shorter than I would like, but I'll give them a try this winter. I can always replace them with 8'ers later if I don't like them.
  11. Smokinpiney
    Smokinpiney
    "South" Jersey
    Nice work mike! ItIt's a good feeling knowing your wood is nice and dry under roof
  12. Well Seasoned
    Nice shed! You can even add tarps to enclose it before the snow flies, like some have done here.
  13. thewoodlands
    thewoodlands
    Nice wood shelter Mike, I don't think the cinder blocks will last a long time, they usually end up cracking.
  14. mike bayerl
    mike bayerl
    Yeah. I'm still trying to figure out a permanent solution. Perhaps the pier block as above? Any other ideas are welcome.
  15. Elderthewelder
    Elderthewelder
    Washington State
    Brad38, Shawn Curry, HDRock and 2 others like this.
  16. papadave
    Mike, looks like the ground is pretty rocky/boulder-y. I just sunk my posts in the ground.....no quickcrete. They're down just under 3', but we're mostly sand.
    Is that possible for you?
  17. papadave
    I'm also thinking that you should at least put the posts over the webbing instead of over the voids on the blocks.
    Otherwise, really nice looking shed.
    I'm still planning a couple more changes to mine. The overhangs are way too short....especially the back.
    Shawn Curry and HDRock like this.
  18. jetjr
    jetjr
    Pa/Md line
    My overhang in the back is too short too. I fixed it by hanging some tarps down.
  19. mike bayerl
    mike bayerl
    No chance. It's more boulder than dirt.
  20. mike bayerl
    mike bayerl
    Actually, the front and back overhangs are both the same and both too short. I'll probably hang tarps in the back and maybe a couple feet at the top of the front for this winter, until I have the time and $ to rebuild it. As for the cinderblocks, yeah I'll straighten them up for now, again until I get a more permanent base figured out. Thanks for all of the input, everyone.
    Gark, Shawn Curry, HDRock and 2 others like this.
