Chain slipped off and cut my leg
Discussion in 'Everything Else (off topic)' started by firecracker_77, Aug 23, 2015.
  1. firecracker_77
    firecracker_77
    IL
    Wasn't wearing chaps and my chain came off. Was over before I could even feel it. Cut my leg slightly and a few scrapes. Was lucky. Bleeding wasn't too bad. Did get a healthy truckload of ash. New helper springs kept the truck from sagging. What a difference.
  2. Woodwidow
    Ugh - now you know why you should be wearing chaps!!!!
  3. firecracker_77
    firecracker_77
    IL
    Yep. And they were in the truck at the time. Got a little lazy and had just started. I guess this is a lesson to always have PPE on. At least it was my leg and not my face or my arm.
  4. Woodwidow
    And that you didn't lose a leg!!
  5. firecracker_77
    firecracker_77
    IL
    The chain just popped off completely and slapped my leg. I didn't cut into the leg with the chain on. That would not have been a pretty sight.
  6. wildwest
    Thrilled you are ok, got lucky!
    Woodwidow, Jack Straw, Stinny and 2 others like this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    Glad it wasn't worse. Good looking load there.
  8. HDRock
    Glad it wasn't worse for ya.
    Where you able to determine why the chain popped off, chain to loose, nuts not tight ?
    Woodwidow, unclefess and wildwest like this.
  9. shaggy wood dump hoarder
    menomonie
    X2?
    Any idea of the cause? I always set my chains a little tight start my saw and rev a couple times before I even touch it to wood, shut saw off and double check chain tension, I've had to retighten a couple times. This still isn't bullet proof.
    Interested to hear what may have caused it! Glad you made out on the better end of possibilities!
    Eric VW, Woodwidow, HDRock and 3 others like this.
  10. firecracker_77
    firecracker_77
    IL
    I think chain too loose. Running a 25" bar...should have stopped and adjusted shorted after I started.
  11. coal reaper
    coal reaper
    Nj
    dont forget your boots next time too!
  12. savemoney
    I was thinking the same thing. Footwear is very important. Just got too comfortable with the saw. We all do at some time, and we all benefit from being reminded to keep safety at the top of the check list.
    Eric VW, Woodwidow, unclefess and 3 others like this.
  13. firecracker_77
    firecracker_77
    IL
    Yeah...I know...definately too casual for the work involved. Boots, face shield, and chaps at a minimum.
    I like the tip to run the saw, and check for tightness periodically.
    Am happy with those helper springs though. A must have for anyone with a saggy truck. Makes it drive so much better loaded up.
    Eric VW, Woodwidow, unclefess and 2 others like this.
  14. Well Seasoned
    Could've been way worse, but your ok, chaps on next time, and a good load. Hate to hear of a chain busting and whipping the family jewels or a face shot...........
    Eric VW, Woodwidow and unclefess like this.
