Snow Storm ! ! ! How much are you getting and How high are you cranking your stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Dec 14, 2013.
  1. smoke show
    smoke show
    Pittsfield, Wi
  2. savemoney
    If you had it to do again, would you consider the p68 over the p 61? Also, how often do you open the stove for any attention. The reason I am being so nosey is I am doning another consideration and I have to be able to sell my idea to the wife before I get to spend any big bucks. If I wait much longer, I'll be too damm old to have it name any sence. Thanks
  3. eatonpcat
    Scared me...I had to read that twice, I thought you said it was your first tea bagger!!
    brokenwing, Hoot23 and smoke show like this.
  4. smoke show
    smoke show
    Pittsfield, Wi
  5. savemoney
    "tea bagger", I had to look that one up as I often miss things that have double meanings. Now I am sorry I did!:confused: Some times there really is a generation gap!
  6. Hoot23
    Hoot23
    Alfred, ME
    I know you were asking Sub, but I thought I'd put my two cents in. I thought I would regret not getting the 68. It was $300 more, but I didn't have the extra to spare so I got the 61. Been reading a lot of posts about people's stove not holding up when it gets really cold for a week or two at a time. But after this week, no worries at all. Stove has kept up and didn't have to crank it to 80 to do so. And not really going consuming more pellets either.
    It's one of those rare cases where the product performs like it was advertised to do.
    imacman, DexterDay and savemoney like this.
  7. savemoney
    Thanks Hoot, I am grateful for any information I can get. I really like the idea of not having to change out my vent if I go with either of these two stoves. I'll be talking with my nephew fairly soon. He works for the company that sells them here. He has said he would help with the installation. I am not physically able to do much of anything like that now. I have been hearing a lot about how infrequently these stoves need to be cleaned out, and how well they handle most any pellet with no problems. However, as I mentioned before, I have to sell the wife on this before I can make the switch. She objected when I put this stove in, but now really likes it. Just need to be a little warmer. This year is one that really shows that need. animated-smileys-winter-012.gif
    DexterDay likes this.
  8. Hoot23
    Hoot23
    Alfred, ME
    Good luck with the convincing. I told my wife it was going to be a messy wood eater where she would have to help with the splitting, stacking, and carrying. Or a pellet burner. She went with less work for her.
  9. subsailor
    subsailor
    Winthrop, Maine
    Save, it depends on the size of your house. I'm only heating 1000 sp. ft. on the main floor. House built in 1930. I had insulation blown in and I have replacement windows, but a lot of them so I have to deal with that. No open concept at all, all small rooms. All said, though, the P-61 does me fine. When the sun is out, piece of cake. Cloudy and windy, the stove has to work. Had it on heat level 5 a couple of times for a short period. Usually between 2.5 to 4.
    savemoney likes this.
  10. subsailor
    subsailor
    Winthrop, Maine
    Save, how many BTU is your current stove?
  11. savemoney
    Sub BTU's: 8,000 - 43,000, heating area 2200 sq ft, but keep 3 bedroom doors shut. raised ranch. stove in the finished basement and temp are fairly even up and down
  12. subsailor
    subsailor
    Winthrop, Maine
    Does it come close to heating the house?
  13. savemoney
    yes, it does except when the outside temps goes down in the teens or less. So, 20 F, the house is warm, under 20 F crank it up, but sustained lower temps and assist is needed. We are using the furnace back up, and she has the little electric space heater she drags around with her.
  14. subsailor
    subsailor
    Winthrop, Maine
    The P-61 will crank some heat and should do the job. But this spell of weather is testing everyone's stove. And it's really just a normal Maine winter. I just hate to see you buy one and then wish you bought the P-68. Rocky always has P series running in his store. Maybe take a ride over there and check one out?
  15. savemoney
    yes, I agree. I want to talk to my nephew about this also. He works there and does a lot of their tech work. I need to keep the cost down, but also be realistic. Maybe a few more things I need to button up to prevent heat loss. thanks
    If you listen to the critics, they tell you that pellet stoves are "space heater" Most of us here feel we depend on them to heat our homes as primary heat. The furnace is backup.
  16. subsailor
    subsailor
    Winthrop, Maine
    My furnace is dead. The 25 PDVC is my backup.
  17. smoke show
    smoke show
    Pittsfield, Wi
    yes they are space heaters. the space I want to heat is my home. :D
  18. DexterDay
    Heard that line before ;)
    will711 likes this.
  19. smoke show
    smoke show
    Pittsfield, Wi
    sorry.
  20. will711
    will711
    Pocono Mts.
    From the dark side:eek:
    smoke show likes this.
