Woot Somersets, FINALLY!!!!!!!!
Discussion in 'The Pellet Bag' started by jtakeman, Aug 17, 2015.
  1. jtakeman
    Got my replacements. Thought they'd only have GS's by the door, But got lucky with some TSC branded. I giggled a little once I saw the UPC! :banana:
    :cheers: :drunk:
  2. ttdberg
    ttdberg Pellet Pig
    CT
    Chows!
  3. jtakeman
    I hope them stacks keep building and they push out all the GS they say everyone wants!! ;)
  4. imacman
    imacman
    Denver, NC
    Energex
  5. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Let me know how those tsc energex burn for you. Im sitting on a ton of them
    imacman, ttdberg and jtakeman like this.
  6. jtakeman
    I got a couple last spring and they burned just like the Stove Chow's I got at HD. Good heat and about average ash. I was please with them.
    IHATEPROPANE, imacman and ttdberg like this.
  7. ttdberg
    ttdberg Pellet Pig
    CT
    They were one of the hottest pellets I burned last season. Depending on the batch, the most ash too! Got 2 tons in the bunker now...
    IHATEPROPANE and imacman like this.
  8. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Really dark pellet correct?
    IHATEPROPANE and ttdberg like this.
  9. jtakeman
    I didn't open these yet. I suspect they are cream colored like the ones I snagged in the spring. I think this could be the same batch that they received in April.
    ttdberg and imacman like this.
  10. ttdberg
    ttdberg Pellet Pig
    CT
    The ones I grabbed in the spring were super dark, just like the ones in the "real" chow bags I had picked up at HD late last year. The two tons I just picked up recently are not that dark color anymore, so they must be from a different batch.
    jtakeman likes this.
  11. unbidden
    unbidden
    RI
    I burned 3 ton of Sets winter past. I get ya with dark. Some say they had a bit of hickory/red in them. All in all I was still happy with them,,,,,, specially the ones from TSC for $250 per ton.
  12. jtakeman
    I think mine are mostly red oak, Maybe a bit of white mixed in. Light redish in color. Won't know how they burn until the cold gets here. Ain't burned em in ions, Sure hope they crank the BTU's like they used too!!
    Edit: Pic of the pellet color.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    They said when Somerset has a heavier than normal run of Hickory is when their ash level increases. I've burned them and love them...so does my father in law cuz I always hook him up with freebie 'Sets!
    eatonpcat, will711, schoondog and 3 others like this.
  14. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Thats how mine looked last year. Smelled like differential oil to me last year but burned well. When I said real dark pellets I meant the tsc energex. Almost black
    IHATEPROPANE, slvrblkk and jtakeman like this.
  15. mithesaint
    mithesaint
    NW Ohio
    I can confirm this, at least the ashy part of it. The Sets that I have right now are much, much ashier than other batches I've burned in the past. Still good heat, but need to clean more often.
    IHATEPROPANE, jtakeman and slvrblkk like this.
  16. jtakeman
    Ewww, Thats not good!! Luckily mine have a neutral smell.
    ttdberg and slvrblkk like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    Also know as "rear end grease" to the old timer mechanics....which I think is weird cuz it ain't grease but it sure does stink!
    eatonpcat, imacman, jtakeman and 2 others like this.
  18. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Yeah the smell was heavvvy. Almost to the point of returning the only batch of somersets I found all seasono_O
  19. unbidden
    unbidden
    RI
    The rename from "rear end grease" to "differential oil" is the first instance of political correctness on record ,, , me thinks:hair:
  20. slvrblkk
    slvrblkk
    Northampton, PA
