How much wood do you all use?
Discussion in 'The Wood Pile' started by MissouriFrontier, Aug 17, 2015.
Average annual wood consumption
Poll closed Aug 31, 2015.
  1. 1-3 cord
    27 vote(s)
    35.5%
  2. 3-5 cord
    27 vote(s)
    35.5%
  3. 5-7 cord
    10 vote(s)
    13.2%
  4. 7+ cord
    12 vote(s)
    15.8%
  1. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    I thought it might be intresting too see the differences in annual wood consumption region to region, stove to stove. I'm aware that the variables are endless. The poll is unscientific. Please vote and also leave a response including your selection and the some of the specific variables that bring you to that number
    Ps I've never started a poll before I hope this works!
  2. lukem
    A lot. Pre-EPA stove...heating from the basement. I can burn 7-8 pretty easy.
  3. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    My house was built around the idea of wood heat. It's small well insulated and my stove is efficient. I use about 2.5 cord a year.
  4. cnice_37
    cnice_37
    4-5 cords, 1900 sq ft with a much too small insert as the workhorse in coastal Mass. Insulation is pretty decent, windows are not but are being addressed.
  5. Well Seasoned
    Typically 3.25-3.5
    Last 2 years being extra cold and snowy, around 4.25-4.5
    I think this year will be like the last 2 seasons.....
  6. HarvestMan
    HarvestMan
    Southeastern Michigan
    I voted 3-5 as that was the range with my old stove. Looking forward to seeing how much I use this winter with my new WS Fireview.
    Variables:
    1. ~2500 sq ft two story (2x6 walls, good attic insulation, poor windows all sealed with 3m kits)
    2. target temp range 70-72 day, down to 65 at night is OK
    3. 28 foot class A on high ground (installed key damper - not sure if/how I will used it)
    4. mixed hardwoods (white & red oak, black cherry, elm)
    Shawn Curry, wildwest, Brad38 and 3 others like this.
  7. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Yeah well seasoned, we are expecting colder than average here too.
    Harvestman keep us posted on that Fireview. Woodstock makes some damm fine looking stoves.
  8. papadave
    Almost invariably 5 full. I voted 5-7, but could have gone 3-5.:headbang:
    As I've mentioned in the past, in more recent years the BTU count has dropped as I've been using more and more Pine and Maple.
    When we first got here, it was all Oak, all the time. 5 cords of Oak isn't the same as 5 cords of mixed.
    Last 2 winters were bad. I thought for sure, with the new stove, I'd use less, but nope. That's what happens when the temps stay lower than normal....longer than normal.
    Some other variables that I won't mention, but the insulation has been somewhat improved, with more to go. Need....NEED, new windows in the stove room. Those have to wait until next year.
    New attic stair hatch insulated cover which helped a lot, and I may put a new storm door in the back of the house before the cold hits. With a house built back in the early 70's, I struggle with what is now considered crappy workmanship (I would have considered it crappy back then too).
  9. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Maybe crappy workmanship Dave. But, at least it sounds like you have a plan. It's just money, right? :picard:
    wildwest, Brad38, schlot and 2 others like this.
  10. shaggy wood dump hoarder
    menomonie
    Heat with a owb, in a old farm house that leaks air like crazy, but it's getting better with better windows tyvek and more insulation in redone rooms, west central Wisconsin, and I burn anything and everything for wood, so long as it's at least somewhat dry, summers have been pretty busy but I'm hoping to get 4 years ahead next summer
  11. papadave
    And time, and energy..............:thumbs:
  12. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Uphill battle Shaggy! Keep up the good fight. With the amount you must burn four years ahead is quite a feat!
    wildwest, Brad38, gboutdoors and 2 others like this.
  13. shaggy wood dump hoarder
    menomonie
    Oh it is, but it helps all the wood I've been getting is from the wood dump about 6 miles away, so getting a full cord in a day with the pickup and a trailer isn't a gigantic undertaking.
  14. jetjr
    jetjr
    Pa/Md line
    I'm in the same boat.
  15. GrJfer
    GrJfer
    The Woods of Arkansas
    I voted 1-3. Hardy outdoor wood furnace heating about 1700 sq ft. Plus domestic hot water. Insulation isn't the best, but not the minimal either. 2.5 is my normal use.
  16. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    Sounds like a pretty efficient stove
    wildwest and Brad38 like this.
  17. Brad38
    Brad38
    S. Indiana
    This will be my first year burning, so I did not vote. Great thread! Good to see everyone's high-level breakdown.
    I have 2,350 sq ft ranch built in 2001 with good blown-in attic insulation, 2x4 walls with batt insulation, and average windows/doors. Have the Woodstock IS. I've already purchased a little over a cord of mixed, with plans to buy 3 more. (Going cl shopping for the free stuff for '16-'17) hope that'll be enough btus!
  18. MissouriFrontier
    MissouriFrontier
    BFE north of KC
    That's a lot of house will be interested in hearing your answer to the topic question next year.
  19. wildwest
    Historically we did 6-8 with old pre-epa stove in old house.
    First winter in new home was about the same with 2 stoves, a dilapidated cat stove and a second pre-epa stove.
    Second winter in new home, replaced both stoves, 8 tons of pellets, and 2-3 cords through xsmall epa insert.
  20. Canadian border VT
    last winter 12 plus but inefficient stove and wood must have not been seasoned enough. 85 % sugar maple..
