Timber Champ Log Splitter
Discussion in 'Chainsaws and Power Equipment' started by bushpilot, Aug 12, 2015.
  1. bushpilot
    bushpilot
    Eastern Washington
    One of these is $399 locally (plus sales tax). I split pine, douglas fir, and western larch. Currently I am using a 5 ton electric, and an X27.
    What are your thoughts?
    Greg
    94BULLITT, Hammy, Thor and 4 others like this.
  2. Stinny
    Buy it! Build a rugged small work table that puts it right at the height you want, and catches the splits... that's 10x faster than the 5 ton electric/hydraulic splitter I had.
    Hammy, Thor, Eric VW and 2 others like this.
  3. bushpilot
    bushpilot
    Eastern Washington
    I can't find any reviews. Could be a bad sign ... or maybe I need to pave the way!
    greg
    Hammy, Eric VW, unclefess and 3 others like this.
  4. Stinny
    At least it's around the price of the elec/hyd units.
  5. bushpilot
    bushpilot
    Eastern Washington
  6. HDRock
    Looks ok and the price is not bad, sure is fast.
    My 7 ton electric did a real good job, it was faster than your average 5 ton because it had 2 speeds.
    Put that puppy up on a stand with a back table you could make a lot of splits, pretty fast
    Hammy, Thor, Eric VW and 1 other person like this.
  7. KaptJaq
    KaptJaq
    Long Island, NY
    It appears to be quick but I have a few concerns:
    1. Two handed controls. No way to hold or catch the splits. This means that every time you have to do multiple splits on a round you have to bend down and pick them up.
    2. Max 20" length. Too short for my stove. Also in some videos that try 20" rounds it takes several hits to split. (Including DR and Speedco kinetics)
    3. Hard to split wood takes several hits and there is nothing to dis-engage the split from the blade.
    4. It is fast but on the stuff in that video an axe would be as fast if not faster.
    If you are not splitting near a power source it would require a heavy duty extension cord or a decent size generator.
    If what you are splitting is clean and not too long it is probably easy and fast. I use an axe or light maul for that stuff.
    KaptJaq
  8. HDRock
    The one thing I did not like about my electric was the two hand operation but I fixed it so it was one hand operation
  9. cnice_37
    cnice_37
    I use the hydraulics nowadays for what I can't do by hand. I don't think that little bugger would help on those.
    If you are looking to avoid hand splitting all together, it looks like a decent option.
    BUT... few who have ventured down the kinetic path have faired well. I would not be the guinea pig on a low cost (cheap) kinetic splitter.
    Hammy, Eric VW and Horkn like this.
  10. Butcher
    Butcher
    I aint no x-pert but I did stay at a Holiday Inn once. It just seems to me that of all these video demonstrations of the newest fastest biggest bad azz cheap splitter I have ever watched over the years it seems like the rounds they are splitting are all so freaking dry already that they really don't need splittin and if they do need downsized to fit in the stove an axe would do the job. That's just me cuz I like to see, touch, and smell what I am plunking down my hard earned cash for. Your mileage may vary.
  11. MasterMech
    1300W of input power, a small (2k watt) inverter generator would run that pretty comfortably if power wasn't available. Also you don't need a monster extension cord for that either. A 14 gauge cord would probably do just fine for lengths under 100'.
    +1 on these videos for small splitters using very easy rounds to split.
    Pallet Pete and Horkn like this.
  12. Mag Craft
    If it were me I would save my money up until I had enouph go get one of the many 22 ton splitters such as the Speeco.
    I do not believe that splitter will do anything more than your 5 ton you have now will do.
    Hammy and Eric VW like this.
  13. Cowcatcher
    Cowcatcher
    Valleyford, Wa
    Greg,
    I found this topic on a search the other day as the only one that had a comment on this product. Of course not much info though as you found. I went ahead and bought it yesterday to take a chance on it.
    It did a wonderful job on the first 5 or 6 splits then it didn't. I will be calling the manufacturer this morning to see if they have a fix but if not I am going to see if North 40 will refund the purchase.
    A few pre failure observations. It is really heavy. The wheels are tiny making moving it on anything other than a constructed floor difficult. It was packed well and assembly was simple. It included a replacement belt, a Phillips head screw driver and a combo 12mm/14mm wrench. You only need the 14mm to assemble which consists of attaching the ground rest/handle on the end of the table with two bolts. The screw driver is used to remove the shields to replace the belt.
    I was splitting pine cut a year ago. The unit worked excellently on the first few splits although the release handle sometimes gives a jarring kick. I started out with some pieces under 12" then moved up to pieces about 16" to 20" and again it worked well until I hit a knot. It stalled and since it throws a series of weak, short strokes with little force.
    I will report back after I talk to their support staff.
    94BULLITT, Hammy, Oliver1655 and 3 others like this.
  14. bushpilot
    bushpilot
    Eastern Washington
    Welcome to the forum Cowcatcher ! Thanks for the report, in the end I had enough doubt to where I did not jump at this. Your experience seems to confirm this.
    Let us know how it goes with the manufacturer and North40.
    Greg
    Hammy, Eric VW and cnice_37 like this.
  15. Cowcatcher
    Cowcatcher
    Valleyford, Wa
    Greg,
    I am not giving up on it. Here is the response I got back from the manufacture after sending them pictures of the motor plate and pieces of the broken pinion I found under the unit when I tipped it over to find the plate and photograph it.
    Let me add that the reason I went ahead and purchased it was how much faster it split. There is a 7 ton hydraulic on Amazon available for the same price but watching how slow it split was painful.
    Here is Timber Champs reply:
    Dave,
    Your pictures are showing me that the pinion in fact did break.
    We have seen this on occasion and usually we send out new replacement pinions but in this case I would like to send you a new unit.
    You may scrap the other unit or use for parts but if you would like to send me an address where I can send you a new unit I will get one shipped out to you with tomorrows trucks.
    Again, thank you for your purchase and we apologize for the inconvenience.
    Regards,
    Stephiedoll, 94BULLITT, Hammy and 9 others like this.
  16. bushpilot
    bushpilot
    Eastern Washington
    Wow! That sounds good!
    Greg
    Cowcatcher and Eric VW like this.
  17. cnice_37
    cnice_37
    I hope that works out for you Cowcatcher
    My cautious side is saying get the refund or have them agree to an extended warranty. A busted pinion already and a known issue...
    Hammy, Cowcatcher and Eric VW like this.
  18. bushpilot
    bushpilot
    Eastern Washington
    BTW, thanks for joining the FHC, and for adding this information here. As you well know, there is nothing on the web about this splitter, now we are the cutting edge :dex:
    I hope you stick around.
    Greg
    Hammy, MasterMech, Cowcatcher and 2 others like this.
  19. HDRock
  20. Cowcatcher
    Cowcatcher
    Valleyford, Wa
    I may stick but I am not a big wood cutter these days, just cleaning up Ponderosa, apple, cherry, boxelder, aspen and hawthorn around the edges of the farm. Last fall, after the crops were off, I hired a tree climber friend to limb some ppines with branches twice as big as my arm that were taking 25 foot bit marks out of my fields plus tearing up combine and tractor cabs and other equipment. This year will be at taking the edges of an old orchard and some really big old weedy hawthorns. It is a multi year project that ultimately ends up in my fireplace. I have also down graded from using my Stihl to a 16" rechargeable GreenWorks. ;) Old age is a ruthless judge!
