How often do you dust your cat?
Discussion in 'Modern EPA Stoves and Fireplaces' started by fox9988, Dec 16, 2013.
  1. fox9988
    fox9988
    NW Arkansas 72717
    My cat was getting a little sluggish. I checked it and there was a lot of fly ash on it. I dusted it with a paint brush before I got any pics, but here are some before and afters of the air scoop screen. image.jpg image.jpg image.jpg image.jpg This was after only 1/3 cord of two year CSS red oak. Seems excessive to me. What do y'all think?
  2. milleo
    milleo
    I don't have a kitty but ya if I did and it got dusty I would dust as needed...:p
    Pallet Pete and mattjm1017 like this.
  3. mattjm1017
    mattjm1017
    I do mine as needed which ends up being every couple of months I guess I dont really keep track of it but I did notice some build up on the screen so Ill give it a brushing next weekend when Im off. I think I took it out some time in September or early October last time.
  4. clemsonfor
    Do sent look bad to me? Is that your cat? Mine is square holes and 2"s thick. I pull it once a yr. And that equates to 1.5-2.5 cords.
  5. fox9988
    fox9988
    NW Arkansas 72717
    That's the air scoop screen, before the cat. I had already dusted the cat before I thought to take any pics.
    Needing dusted at 1/3 cord seems excessive. For some people that would be once a week.
  6. charlie
    charlie
    Schoharie, NY
    I just reach up in my PH with a paint brush and dust the screen before reloading, if I see it's getting build up... works good... Did that with the Fireview as well..
    fox9988 likes this.
  7. clemsonfor
    I don't mess with mine cause I have to drip a housing and it needs to be cool to do it so I need like 36 hours to cool to do it. I sometimes get that span but in dead winter it ain't coming out!!
  8. Pallet Pete
    Pallet Pete Moderator
    Ovid
    If I dusted my cat she would scratch the crap outa me...
  9. Todd
    Todd
    NW WIS
    I use a long handle grill brush to clean off that scoop screen as needed. No need to pull it out, I can do it before reloads. As far as the cat I remove the scoop, brush and vacuume about once every cord burned.
    fox9988 likes this.
  10. fox9988
    fox9988
    NW Arkansas 72717
    Todd do you ever pull the cat and clean it? I usually just brush one side from the firebox.
  11. KaptJaq
    KaptJaq
    Long Island, NY
    I have to dust him just about every day. If it is lit he is there, laying in whatever dust fell during the last re-load. I can tell how hot the stove is running by how far away he is.
    Waiting for the stove to warm up...
    Ah, it is finally comfortable...
    KaptJaq
    BrianK, Gark, Oldhippie and 6 others like this.
  12. Todd
    Todd
    NW WIS
    Sometimes I'll pull the cat and check everything out mid season if we get some good weather but I don't think it's really needed til the end of the season unless your wood isn't up to par.
  13. savemoney
  14. fox9988
    fox9988
    NW Arkansas 72717
    FYI....if your cats don't like being dusted, there is always the boiling vinegar bath!
    charlie and concretegrazer like this.
  15. Chvymn99
  16. HDRock
    My cat goes behind the furniture and dusts, for me, Once in awhile comes out with cobwebs on his whiskers :) :D
    clemsonfor likes this.
  17. Backwoods Savage
    Or just spraying it with the vinegar/distilled water solution, then rinsing it and putting it back in. Lewis, at Woodstock tried it and said it is working fine. That would be a whole lot better than the boiling; more convenient and faster too. We did the vinegar bath on our cat for the first time this past summer. I really can not say it made things better. I thought perhaps at first that it did but within just a couple fires it was pretty much the same as it had been. However, our cat was not very dirty at all. We did this as an experiment more than anything.
    Like Todd, we now tend to do ours once in mid-winter if we get the right weather then do it again after the end of the burning season or just before the new burning season starts. But then, we only burn about 3 cord of wood per winter.
    clemsonfor and fox9988 like this.
  18. fox9988
    fox9988
    NW Arkansas 72717
    Dusting didn't work. Time for a vinegar bath. Pan isn't big enough so I'm going to soak it for 30 min on each side. Solution turned green, I guess that's a good sign.
  19. Todd
    Todd
    NW WIS
    How old is your cat Fox? Looks like one of the old steel cats that had some problems. WS has a new and improved design and I'd bet they would swap it out for you if it doesn't improve.
  20. clemsonfor
    I put the vaccine to mine but I can't get to the down stream side without pulling and regasketing mine. But I can easily see through all the voids so I don't worry much.
