used 460 price?
Discussion in 'Chainsaws and Power Equipment' started by Smokinpiney, Jul 28, 2015.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    Im a husky guy at heart but a co worker brought in an ms460 that his friend wants to sell. It's got a heated handle and 20" b&c. It starts and runs fine and is pretty clean but compression seems a bit on the weak side. Im bringing my comp tester to work tomorrow to get a true reading. If the compression is where it should be, what's a decent price? I know it's hard to give a number without a pic but just looking for a ballpark number.
  2. jon1212
    jon1212
    Utah........ugh!
    $500-600 if the compression checks out.
    Drvn4wood, Shawn Curry and clemsonfor like this.
  3. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Convince him to let ya pop off the muffler and look at the piston... It could tell you more than a comp reading. As for compression readings on this saw- Mine was at 165 during break in and is probably over 170 now (rebuild w base gasket). You'd want over 150 or so...
    A nice 460 gets between $450-$600 here... Some low hour ones go higher as they are fairly new and well-liked here
  4. MasterMech
    A typical, stock, 460 will blow 155 psi, give or take. Lots of influences, I wouldn't be too worried at anything over 140 psi.
    A mint 460 will fetch $6-700 pretty easily. A rough example that needs work can still sell for $2-300. Condition is everything. That heated handle (full wrap?) is prob worth a few bucks too.
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    Yeah i plan on pulling the muffler also.
    Just a standard handle unfortunately.
    Thanks for the info guys. Im trying to talk another co worker into buying it so i don't haha but he's on the fence as he really doesn't need a 70+cc saw.
  6. jon1212
    jon1212
    Utah........ugh!
    Pssh! Need?
    Yeah, I fail to see your point.
  7. MasterMech
    A half-wrap heated handle model? Such a creature did exist but not nearly as common as the full-wrap. Peaks my interest a bit as I prefer a half-wrap and I do like the heated handles.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Here's a few pics of the saw
  9. clemsonfor
    I would think if it checks out ok it would be I'm the $400-550 range?
  10. mdavlee
    mdavlee
    In my area that's a $4-450 saw. Our area is lower than a lot of others. We don't have the 290s selling for $400
    clemsonfor likes this.
  11. clemsonfor
    Is it me or do I see the same thing 3times? Haha!
    I do it too when I have almost zero signal. You dont know when it takes the post or not.
  12. mdavlee
    mdavlee
    Stupid phone on the edge of service area.
    concretegrazer and clemsonfor like this.
  13. Canadian border VT
    that's all right mdavlee, some of just considered it real important! :D
    clemsonfor and mdavlee like this.
  14. Chvymn99
    Well after pics...Man thats like two different saws. One side looks good the other side is pretty scuffy... Is that a crack off the handle on the case? I cant quite pull up on the picture well enough. It looks like a "Y" coming from the bottom. But in the condition that its in, it would be a good work saw, probably 325 to 425... But I like a good lookin' saw.
    mdavlee likes this.
  15. mdavlee
    mdavlee
    It probably spent a lot of time laying utch side down in the back of a truck.
  16. Smokinpiney
    Smokinpiney
    "South" Jersey
    Well I didn't end up buying the saw but it had pretty darn good compression (160lbs) . Right after I put the saw back together, the owner called my coworker and said he had it sold to someone. Oh well, I didn't need it anyways.
    Chvymn99 that was just a scratch, not a crack.
  17. foragefarmer
    foragefarmer
    Central, Virginia
    Do you have any idea what the sale price was?
