Been researching dump trailers the last month.....
Discussion in 'The Wood Pile' started by Greg, Jul 22, 2015.
  1. Greg
    Greg
    And have I think decided on this one. I would be getting it in the 8 x 16 variety, but considering 8x14 also. But only 250 different in price so leaning 8x16and regular hitch style, not goose neck. Like the construction, really like the drop down sides for loading, heavy duty ramps for times I have to move tractor, scissor lift, built in 110 charger, etc.... Sure would be nice as I will be working with smaller crew to not have to stack outbound, or unload by hand inbound. Maybe I can deliver a little spring mulch or something to help on costs. Please let me know if anyone has experience with Load Trail and has some advice. Looking for a trailer to finish the career with!
    http://www.loadtrail.com/detail.cfm...eneck Dump 14,000 Lb w/10" 12 Lb I-Beam Frame
  2. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Greg,
    Loadtrail make good equipment as do some other mfg's. I used to have a pintle hitch dump trailer for construction debris and many, many more uses. I think you are on the right track using a fifth wheel hitch. The load on the back with the standard hitch or pintle hitch is tricky. Having the load point over the axle is very nice. My rig was homemade by a very good welder friend, who has passed away. He used to fix all the cheaply built ones that broke so he new how to make one that didn't. He did try to get me to use a fifth wheel hitch when I built mine but I was too young and inexperienced to know the difference.
    Finally, don't forget maintenance on heavy duty trailers, they take a beating and regular maintenance cannot be overlooked.
    Greg, mdavlee and bert the turtle like this.
  3. mdavlee
    mdavlee
    My only experience with them personally are Homesteader trailers. One is 6x12 and the other is 14' long. I've had 6 tons of rock in the bigger one and it dumped it fine. It is the dual cylinder set up. If I were to buy one for me it would be gooseneck. It will pull much better and turn easier.
    Greg likes this.
  4. DaveGunter
    DaveGunter
  5. Greg
    Greg
    Many thanks, read thru that whole thread and it was very helpful.
    Think I am leaning towards 16 ft goose neck from load trail
    Will likely be last trailer I buy lord willing, so am going with ramps, 16 ft with removable sides. Sold on load trail brand.
    Will order soon and post some pics first time I get her loaded
  6. Hog_Hunter_57
    Hog_Hunter_57
    Mt.Pleasant TX
    I like big TeX. But they are also made in the town I live in.
    Drvn4wood likes this.
  7. 2manysaws
    2manysaws
    E. central Iowa
    Won't regret gooseneck on a heavy trailer. Got 3 of them.
    Drvn4wood and mdavlee like this.
  8. haveissues
    haveissues
    Hudson Valley
    Greg,
    I just bought a load trail dump last month after looking at all of the brands and found the best price by far on a load trail out in your neck of the woods. I'm sure you found the same dealer-you both have the same first name. If you haven't, let me know and I'll PM you his info. My new load trail is far better thought out than the cam superline I was using until now. It isn't the cheapest, but it is the nicest IMO.
  9. Greg
    Greg
    You are correct on dealer, and i did the deal. Pick it up Tuesday after they install the flip over ball in my bed since its a goose neck. Seems like a straight shooter type guy, and when i needed 16 feet with fold down sides on a dump, really was the only local place i could go. Trailer likely overbuilt for what i need, but am hoping for 20 years (my last 20) of wood cutting out of it.
  10. Stinny
    I've never had a fifth wheel set-up in a truck but I've always thought how awesome it must be backing up and hooking on... can look right at it from the cab... :yes: Congrats on the trailer Greg. Looking forward to pics when you get it home.
    Drvn4wood and wildwest like this.
  11. Greg
    Greg
    Well, here she is. Will forward on some pics whenever i do the first load. 95 here and humid today, so likely won't be cutting unless we can find an evening gig. trailer_72815.jpeg
    dusky, Eric VW, Will C and 6 others like this.
  12. Stinny
    Nice!!
    Eric VW, Drvn4wood and wildwest like this.
