Non-conventional stoves
Discussion in 'Modern EPA Stoves and Fireplaces' started by boettg33, Jul 3, 2015.
  1. boettg33
    boettg33
    Wakefield, RI
    I'm wondering if anyone uses non-conventional stoves. There a bunch of different ones out there. Masonry heaters (my dad calls them Russian stoves), earth stoves, double barrel stoves, etc...
    If you have a non-conventional stove, please share pictures or links to pages on here.
    Thanks
    Jason from RI
  2. wildwest
    Eric VW and papadave like this.
  3. Greenstick
    Greenstick
    By earth stove do you mean the Earth Stove wood stove company?
  4. DaveGunter
    DaveGunter
    Never really saw it in action, haven't been in her hone in years. My MIL has a Russian fireplace in her home. Basically a solid brick wall, maybe 10 ft long by 2 feet wide. A place for a fire in one end and a channel for the exhaust to travel back and forth the length of the wall a few times before going up the chimney. It is my understanding that really dry wood is absolutely necessary, so you can have fairly small extremely hot fires, you wouldn't want any creosote inside the exhaust passage, there is no way to clean it.
    Eric VW likes this.
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    I wonder if homes that have full masonry heaters are considered non-conventional?
  6. boettg33
    boettg33
    Wakefield, RI
  7. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I always loved the "Elm" stoves. Aka the flying pig. I don't recall anyone having one on here.
    Eric VW and My IS heats my home like this.
  8. wildwest
    Eric VW and Backwoods Savage like this.
  9. BDF
    BDF
    I built a gassifing, wood burning stove. It burns 'upside down' meaning the fire is down in the fire pit, and the air moves through the stove from inside where the wood is to below, going through the grate. The biggest advantages are complete combustion and no visible emissions. There are a couple of disadvantages too and that is why I am using an Ideal Steel in my house :) But the gassifier definitely has potential and one of these days I hope to try a new idea out on it to see if I can make it better behaved.
    Brian
    fox9988, Eric VW, jeff_t and 3 others like this.
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    I'm surprised your ideas haven't made it to a big shot yet.
    Eric VW likes this.
  11. jeff_t
    jeff_t
    SE MI
  12. chance04
    chance04
    Denton Md
    Eric VW and jeff_t like this.
  13. boettg33
    boettg33
    Wakefield, RI
  14. Ronaldo
    Ronaldo
    Ha! I may need to watch it again to see if there is actually a stove in the video!:eek::thumbs:
  15. chris
    There are several styles of down draft heaters available from Europe- state side we just lag behind
    Used to be a couple mfg here - might have bit the dust with the EPA requirements dollar wise. I remember at least one furnace.
    Had an aquaniantence that used to build stove /furnace 2.5x3x3 ft ( outside dimensions) basicly a fire box with an air jacket & a blower. Blower had to be on the bottom or low on any side or it would over heat the motor windings. that thing would pump some heat but not particularly easy on the wood pile.
