Snapper mower coil trouble
Discussion in 'Chainsaws and Power Equipment' started by Unicorn1, Jul 1, 2015.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    I have this mower that will start once but not start when hot. I removed the coil and the ends had some build up on then I cleaned, set the gap and it started only once again. I see no engine number on this mower, its a 6.75hp commercial hi-vac model.
    There's the mower tag but no engine info?
    Edit: I found a video that show the engine numbers above the muffler, I saw those numbers but didn't think it was for the engine. Problem solved .
  2. TurboDiesel
    definitely briggs and stratton
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    New coil and still no spark?
    EDIT: I readjusted the coil and it starts great.
  4. TurboDiesel
    not much left to replace
