Husky large mount 72" bar?
Discussion in 'Chainsaws and Power Equipment' started by redneckdan, Jun 27, 2015.
  1. redneckdan
    redneckdan
    Northern Minnesota
    I am looking for a very large husky large mount bar.
    At the tail end of last season I made a pretty nice chunk of change cutting spearing holes. The last few weeks of the season the pike move up shallow and every body and their brother wants to relocate their shack. Usually folks auger two lines of parallel holes and spud the rest then bail the ice chips out. This process takes several hours for those in decent shape. Darn near impossible for your average beer bellied iron ranger.
    I helped a buddy move his and my 36" bar just barely made it, his hole was in front of a creek mouth so the ice was thinner. Other folks saw me finish the hole in under 20 minutes. I had folks lined up asking me to cut. Anyone on the thinner ice I was able to do. The thicker ice I could not reach water. Some was 5 1/2 feet thick. Still, I made about 500 bucks that afternoon and a couple hundred more the following week. Nobody around here has a saw big enough for late season ice, I pull out my 576 w/ 24" at the township yard waste dump and people think I'm nuts.
    I am about 1/2 done with my 395 rebuild and I want a big 'ice bar' for it. 72" .063 preferably hard nose. Where can I find one?
  2. Eric VW
    This is all I could find-
    But it's for Stihl, and it costs $303... Could it be machined to fit the large mount Husky?
    clemsonfor likes this.
  3. stackowood
    stackowood
    Oregon
    Cannon or try Chain Bar Repair in Portland, OR to get one custom made.
    clemsonfor, Bert and Eric VW like this.
  4. Kevin in Ohio
    Kevin in Ohio
    clemsonfor, Bert and HDRock like this.
  5. man of stihl
    man of stihl
    NW PA
  6. Eric VW
    Nice find, man of stihl, wonder if the hardening snafu would matter for cutting ice?
  7. man of stihl
    man of stihl
    NW PA
    Not sure
    Eric VW likes this.
  8. thistle
    thistle
    Polk/Guthrie Counties,IA
    Eric VW likes this.
  9. MasterMech
    A 3003 mount Stihl bar would also work with a cheap adapter/bushings and a drilled tensioner hole.
    Eric VW likes this.
  10. redneckdan
    redneckdan
    Northern Minnesota
    I'm giving the ebay mystery special a try. It won't see all that much use. The water will help keep it cool and lubricated. Now I need to find a chain.
    Eric VW likes this.
  11. mdavlee
    mdavlee
    The forester will probably be fine for your use. Madsens will probably be cheapest for that much chain. They'll sell it 2 for 1. $.39-42 a dl and you get a 2nd free up to the same dl count.
    thistle, clemsonfor and Eric VW like this.
  12. clemsonfor
    I have either run across that ebay auction or seen it posted here before? I have seen that pic of the girl and bar before. Someone called it like a 50+" bar and someone pointed out unless that girl is like 4ft tall they think its bigger than that.
    man of stihl likes this.
  13. redneckdan
    redneckdan
    Northern Minnesota
    Bar arrived today. Holy wah she's a biggun...
  14. clemsonfor
    Id be doing the same as you. Id be the ice cutting man!!! I would do a weekend thing of it. I have an 80cc saw and I would do just like you!!!
  15. redneckdan
    redneckdan
    Northern Minnesota
    I figured out a tripod for lifting blocks out with my atv winch. I usually just shove them under with pike poles but some people want them out of the hole.
    I was thinking about running the 576 buy with the 395 I can run with out the clutch cover if water and slush become a problem. Obviously no brake but done properly kick back is minimal.
    mdavlee likes this.
  16. mdavlee
    mdavlee
    72" probably won't kick up but will have a lot of pushback if the top of the bar gets bound.
    clemsonfor, jon1212 and thistle like this.
