To split or not to split
Discussion in 'The Wood Pile' started by WaddleRemodel, Jun 14, 2015.
  1. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Found a little honey hole to find new supply of lodge pole. Local logger brings out all the smaller logs to his place. Makes fence poles and rails. Big pile of cut offs. Asked if I could go through and what he would need for a trailer load. So how small is to small to split?
    image.jpg First trailer load.
    Shawn Curry, basod, milleo and 7 others like this.
  2. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
  3. Frank and Beans
    Frank and Beans
    When on the fence about whether or not to split, I usually split. Then I know it will be good and dry when I'm ready for it.
  4. redneckdan
    redneckdan
    Northern Minnesota
    I'm one of those 'if it fits, it ships' people. As long as the piece will physically fit in the stove, it goes on the pile.
    If you hit those with a moisture meter I think you will b ed surprised how ready they are. Heavy equipment knocks the bark off, they lay around in the sun and the moisture goes out quick.
    Large chunks of pine can be an advantage. Less surface area exposed extends the burn time.
    Shawn Curry, Drvn4wood, basod and 8 others like this.
  5. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    This is what I usually am able to scrounge.:) image.jpg
  6. bushpilot
    bushpilot
    Eastern Washington
    I split anything that is larger than 6 inches. That said, if some of the bark is torn off, that lodgepole will dry quickly and well.
    Greg
  7. KaptJaq
    KaptJaq
    Long Island, NY
    For me anything 4" or better that still has bark on it gets at least one split. Everything 6" or better gets at least one split. In addition to reducing the dry time it helps the wood pack into the stove better.
    KaptJaq
  8. Gark
    Gark
    SW Michigan
    If I can grab and place a round from the end one-handed, it doesn't need splitting.
  9. red oak
    red oak
    EXACTLY.
    Shawn Curry, basod, Gark and 2 others like this.
  10. Backwoods Savage
    Most of it depends upon your stove. A smaller firebox is easier to pack with small stuff but if you have a big firebox your splits can be much larger.
  11. wildwest
    x2
    Especially since its lodgepole and in a dry climate, and you are so far ahead anyway, I would let them dry on thier own for a year of two if it were me. Also, I tend to like the barked ones for starting a fire.....
  12. prell 73
    prell 73
    ia
  13. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Amazing what you can find if you just stop and ask.:)
  14. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Looks like no more than the 4 to 5 inches. Nothing like short pudgy hands and fingers.:)
  15. Chvymn99
    Nice score...4 & under definitely are safe... Split the bigger ones at least once. But Save a few of the bigger ones for those over nighters....
    Shawn Curry, Gark, basod and 6 others like this.
  16. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Anyone for a game of pick up sticks.
    The cut off pile
    Three loads out = 6 cord +-
  17. Unicorn1
    Unicorn1
    Amarillo, TX
    It looks like you have your work cut for you!
  18. WaddleRemodel
    WaddleRemodel
    Southwest Wyoming
    Not bad for 15 min from house. All blocking done in my yard. Just can't yell timber.:)
  19. bogydave
    +1
    Nice to have various sizes of splits.
    What's a cord end up costing ?
    With birch, if it's to be firewood, I split everything at least once.
    Drvn4wood, WaddleRemodel and Deacon like this.
  20. KaptJaq
    KaptJaq
    Long Island, NY
    For me it is my time & materials (gas, oil, chains) only. I either scrounge or get rounds from the tree service. If one of the crew drops the tree service load I'll give him $20 for his efforts. Tree service load is about a cord. My scrounge loads are about 1/3 of a cord each.
    I still hand split so it is not even that much gas...
    KaptJaq
    firecracker_77 and WaddleRemodel like this.
