The joys of "pre-owned" homes
Discussion in 'Everything Else (off topic)' started by bassJAM, Jun 1, 2015.
  1. bassJAM
    bassJAM
    Cincinnati, OH
    I was clearing out some brush next to my detached garage recently to open up some more stacking room for my firewood, and noticed a palm sized piece of glass in the dirt. I bent over the pick it up, and noticed there was a lot more. I ended up getting a shovel and dug up four 5-gallon buckets worth of broken window glass that previous owners must have dumped in the side yard, and then let the entire area grow up into weeds and honeysuckle after they made it unsafe to use. I’ve found several other questionable things that the previous owners had done in the 3 years I’ve lived here, but dumping glass in the yard is by far the worst.
    So what “surprises” have you guys found after buying a pre-owned home?
    cnice_37, basod, Gark and 4 others like this.
  2. Certified106
    Certified106
    In The Hills
    We bought our current home as a short sale so I wouldn't say we were surprised but they let the dogs and cats use the floor as a giant litter box for years which necessitated ripping up certain sections of the floor and replacing the subfloor, they took all the light fixtures and fixture globes, stole the remotes to all the ceiling fans, took all the light bulbs, left broken down furniture and cats in the basement, left the garage piled 5 foot high with garbage, had to flood the basement and scrape the cat and dog poop off the floor and sanitize all the concrete, slung paint all over the bedroom walls and bathroom with smeared handprints all over the walls and they left all their nasty pet cock roaches running everywhere.
  3. bassJAM
    bassJAM
    Cincinnati, OH
    My house was a foreclosure, but surprisingly they didn't do much that was destructive. There were 3 rooms that had wallpaper, and in each of those rooms they tore off one strip of wallpaper. They also took all of the crown molding out, and most of the floor trim. But they left all of the CFL bulbs and didn't damage anything else.
    basod, Chvymn99, Certified106 and 2 others like this.
  4. Backwoods Savage
    One time we found some of those weeds in the flower garden were something that should not have been growing there! Naturally, it was one of our sons who seemed to know what it was....
  5. bushpilot
    bushpilot
    Eastern Washington
    We have hauled several tons of trash out of the woods, and dug out of the yard. They bulldozed a lot of stuff under, still finding lots of carpet, of all things.
    That was after they cleaned it up, which I will admit they did haul a lot of stuff away!
    Greg
  6. Greenstick
    Greenstick
    The mostest OMG moment was...We bought my wife's Grandparents place from the estate. As we have been fixing up we recalled Grandma saying she had someone fix an outlet that quit working. In the basement I found a joist with old wires run thru and about 6 feet of charred joist. Only thing that saved the house was a damp basement.
    basod, Gark, Backwoods Savage and 5 others like this.
  7. Norky
    Norky
    Most everything at this house was fine. The biggest problem I found was shoddy wiring work, like tapping into existing wires and wrapping it up with tape. One thing I still need to take care of is the electric to the attached garage. It consists of a piece of romex that's buried about 4 inches down and goes from the house to the garage, but at least it's grounded and goes under the patio.
    The older houses in this area often have a spot on the property where there was once a big pit where the home or farm owners would dump all of their garbage or some would just dump it over the side of a hill. Sometimes, heavy spring rains will expose some of the garbage and cans and bottles can be seen poking through the surface of the ground. Another thing people around here used to do and some still do, is dump their old shingles somewhere on the property. But glass?...that's just low brow.
    basod, wildwest and Backwoods Savage like this.
  8. bassJAM
    bassJAM
    Cincinnati, OH
    I found that pit at my place out in the woods where the owners were dumping trash too. But it's not because it's an older home, it's probably because they bought the house in 2004 and had lost it by 2008 and must have stopped paying for trash removal for several months along with not paying their mortgage. Luckily their trash pit is full of plastic so it's safe and easy for me to clean up. It's all good though, besides that glass I can deal with the rest of the crap. That's the price you pay when you get a deal on a foreclosed home I guess.
  9. schlot
    schlot
    NW Iowa
    You too? We have a broken glass collection from our back yard. What would make someone think throwing broken glass into a yard is a good idea??
    Farging iceholes! :)
  10. 343amc
    343amc
    Northeast Lower Michigan
    I had to replace the drain line between the house and septic tank in 2003. As I was digging the old pipe out, I uncovered lots of scrap tile pieces that were apparently thrown out the bathroom window when the house was built. When I dug the trench to run power out to my barn, I found the dumping ground for the brick scraps.
    Took well over 40 years from burial until that stuff saw the light of day.
    wildwest and schlot like this.
  11. Gark
    Gark
    SW Michigan
    The 2 X 10 floor joists , being 6' longer than the outside wall, extended through and beyond the east wall and they nailed 2 X 4's to those. And added railings - that was their deck. With someone walking on the deck, you could feel the living room floor flex up and down. So there were non-treated 2 X 10's as deck joists out in the weather for a couple of decades. No vertical supports at the outside edge of this "deck". We removed it right away. I've never heard of building a deck like that.
    cnice_37, basod, StickBender and 2 others like this.
  12. MasterMech
    Jeez, the least they could've done was leave you a decent cat. :rofl: :lol::p
  13. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    You are not alone. You'd cringe at what I'm replacing.
    ( the dawg hit a soft spot, punched a hind leg through the plywood cover on the existing crap deck. dawg doesn't go there, anymore. ).....not even for bacon.
    She learned... :rolleyes:
  14. wildwest
    I have dealt with all the below in different homes
    dog in yard
    replaced many sheets of subfloor, bleached and kilzed the rest, baseboards beyond sanitizing from cats. This was not a foreclosure but just looked dated inside............it was the smell that had to experience in person. I did the painting on a rare weekend without my lil one, posted about it here, even the dogs got in the act helping me paint the floors :)
    We had an electrician to gut the entire house, I don't have to worry now. Cost a bundle but worth it IMHO.
    Our home was the same!! Except had telephone poles under the deck, that the joists sat higher than :rofl: :lol: We had an engineer specify to install 6 x 6" posts before we put on a heavy cement tile roof, otherwise the deck would still be suspended :whistle: AND, that was our first home, it passed FHA inspection :loco: :crazy:
    My geriatric brittany's rear leg pushed through a knot hole on that same old deck, I used duct tape incase she walked there again:whistle:
    No dumped glass though, just an occasional shard. Interesting.
    basod likes this.
  15. wildwest
    Oh, and we are currently working through outbuildings full of things from several previous owners + renters. Landfill fees adding up $$$$:headbang::hair:
    Chvymn99, basod and Certified106 like this.
  16. wildwest
    Hover deck?
  17. IHATEPROPANE
    IHATEPROPANE
    I have plenty of things to select from. My favorite was they hung cabinets using the plumbing for the upstairs shower drain. You can imagine what happens when you put screws into pvc that has water run through it....:picard:
    Chvymn99, basod, wildwest and 3 others like this.
  18. schlot
    schlot
    NW Iowa
    Say what?!?!
  19. reelcrzy
    reelcrzy
    Plymouth MA.
    We purchased our house on a short sale as well. Last year I cleared an area in the woods next to the house for 4 30' stacks. As I was clearing I realized that the ground was oil soaked. That's when I started uncovering about 10 used oil filters and even dug up a motor oil draining bucket. Some people just don't give a sh#%. Other than that no other surprises so far ( knock on wood )
    basod and wildwest like this.
  20. savemoney
    I am "told" that weed is good to manage pain without all the nasty side effects. I found a suspicious plant growing in my garden once. It was outside under my son's window. That plant grew faster than most other weeds. When I found it, I tour it out and tossed it into the fire pit. My son told me it was the wrong sex and of no use. What do I know. I only know I didn't want any trouble.
