Husqvarna Primer Bulb...
Discussion in 'Chainsaws and Power Equipment' started by fox9988, May 22, 2015.
  1. fox9988
    fox9988
    NW Arkansas 72717
    is shot on my 223l string trimmer. Can the rubber be replaced or do I need the whole plastic housing with the rubber in it? Plastic housing has clips that mount it in a hole and has fuel ports on the back. I forgot to take pics, will try to steal some off the net.
  2. fox9988
    fox9988
    NW Arkansas 72717
    [​IMG]​
  3. Gunn
    Gunn
    Plover, Wi
    You need to replace the bulb assembly.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Good thread, I have some husky stuff too. Just for reference in the future
    fox9988 likes this.
  5. fox9988
    fox9988
    NW Arkansas 72717
    The "local" hardware sales and services Husq. They had one in stock today so I should be good. Thanks for the input.
    concretegrazer likes this.
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    I buy them in bulk. Thinking $2 apiece. Everything uses those dang things or one other style like on the wild thing. ;)
    fox9988 and clemsonfor like this.
  7. clemsonfor
    Same one was on my earthquake. It got pulled amd lines capped as a molded line had to be cut and I could not hook it back up. Then I got a new carb that did not have the fitting for it so the line to the carb was pulled and there is just a blank spot on the saw. I may put the bulb back so it kooks stock...just won't function.
    fox9988 likes this.
