Well,,splitting the gnarly maple didnt last long
Discussion in 'The Wood Pile' started by Ashwatcher, May 15, 2015.
  1. Machria
    Machria
    Long Island, NY
    So what happened here, did a split hit it and break it off, or did just the pressure break it off...?
  2. Ashwatcher
    Ashwatcher
    West By God Viginia
    Bad casting-see pics-pressure built up on the gnarly slab and forced the breakage
    Horkn likes this.
  3. haveissues
    haveissues
    Hudson Valley
    There shouldn't be any real pressure in there since it is the return unless something is seriously wrong. Fluid is always pumping around in a loop through the filter and only gets diverted through the cylinder when you pull the handle. In fact, if you were splitting gnarly wood your splitter was probably in low speed and therefore pumping only 3-4 gpm creating even less pressure in the filter. Must have been a bad casting.
    Deacon and Horkn like this.
