how hot do you let your wood stove get
Discussion in 'The Wood Pile' started by gunny100, May 17, 2015.
  1. gunny100
    gunny100 Banned
    lebanon,pa
    how hot do you let your fire get in your wood stove
    i was told to let it get 800 to 1000 degresse
    so their is not much cresote sooot build up
  2. fox9988
    fox9988
    NW Arkansas 72717
    800 is pushing a plate steel stove, stove top. I'd not get it above that. 675-700 for a soapstone.
    Better to monitor pipe temp to control creosote. I monitor both, + cat temp.
  3. KaptJaq
    KaptJaq
    Long Island, NY
    Depending on need I try to stay between 500°F & 700°F. Much higher and some of the steel will start to glow red. Your best creosote controls are if your wood is well seasoned and you have either an internal flue and/or your flue is insulated. Keep the flue gases warm and dry and you will not have a problem.
    KaptJaq
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    I have an insert and the only way I can measure stove top temp is with an IR gun through the top vent at a low, glancing angle. I don't know enough about IR guns to say how accurate a measurement method that might be, but I intentionally run it at 500-750 depending on the weather. Unintentionally I've gotten readings a bit over 900 a couple of times right around the flue exit, but it hasn't seemed to hurt anything.
  5. jeff_t
    jeff_t
    SE MI
    Perfect.
    Internal flue temps of 800-1000 won't hurt anything, though wasteful. Stove top temps that high could make stuff glow, and prolonged high temps might start warping parts and popping welds.
    Magnetic thermometers aren't always super accurate or responsive. My IR shows big variations in temps, even in an inch or two in different places on the stove. I keep a magnetic on both stoves, but if I'm concerned about high temps, I pick up the IR.
    fox9988 likes this.
  6. papadave
    Which is exactly what the previous owners did with our old Ashley step-top steel stove.
    I had the thermometer pegged many times before discovering that little gem of a problem. No idea what the actual temp was, but the stove never glowed.
    If I'd known better at the time, that stove would have been replaced.
    jeff_t and Backwoods Savage like this.
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Your stove will "tell" you when its too hot. :eek:
    Norky, jeff_t and Stinny like this.
  8. Tsquini
    Tsquini
    The only time I get my stove top to 1000* is when I'm smelting ore in my living room.
  9. papadave
    Thought I was the only one...........:whistle::D
    firecracker_77 and Deacon like this.
  10. yooperdave
    Yeah, at 800-1000 you wouldn't have to worry too much about creosote buildup! Though, it may open the possibilities of another worry or two! Clearance to combustibles anyone?
    Backwoods Savage, Gark and papadave like this.
  11. Backwoods Savage
    Good on you gunny for asking this question. Stove manufacturers will give recommendations on how high of a temperature you should never get above. It can be different for different stoves. In our case, the Fireview soapstone has a 700 degree maximum recommendation. We know many have exceeded this and we have but only by a few degrees. Most of the time in winter we have the stove top at 500-650 or even closer to 700.
    Now about the creosote build up, that is old school talk and it is sadly out of date. Get your wood dry and if you have a good chimney, you won't be fighting creosote with today's stoves. In fact, you will not have to clean the chimney as often either because today's stoves burn super clean.....if your fuel is good. Burn bad fuel and you'll get bad results. I usually ask if people would intentionally put poor fuel in their cars or trucks. Well, why would anyone put bad fuel in a wood stove and expect to get good results? It won't happen.
    Get on the 3 year plan and no worries. In fact, you will burn less wood and get more heat.
  12. red oak
    red oak
    Yeah 500-700 is about where I try to burn. I have burned higher but I get that "you're burning too hot" smell and years ago I made the Fisher glow red. I'm definitely not going to do that again!
    Backwoods Savage and burndatwood like this.
  13. coal reaper
    coal reaper
    Nj
    my boiler gets to 2200* and everything in the secondary chamber glows red. :p
  14. Highbeam
    Highbeam
    I run the noncat Englander up around 750 on purpose. Measured at the hottest place. That stove seems to settle at that temperature and the paint has not faded, no parts glowed, at that temp.
    In the house I have a blazeking cat stove that spends most of it's life at 400 degrees stove top temp. I have seen it as high as 650 during manufacturer recommended burn outs.
  15. chris
    nc 30 depending on feed,try not peak over 700 when I leave in morning mostly into cruising around 500
  16. prell 73
    prell 73
    ia
    I run my stove around 500 that seems to work the best for me
    papadave likes this.
  17. Butcher
    Butcher
    Yeah, me too. Then I open all 3 doors on my Oslo and start banging out horse shoes on the top of it just for the heck of it.:D
    Gark, Brad38, Stinny and 4 others like this.
  18. fox9988
    fox9988
    NW Arkansas 72717
    Surface temp? If so, I'm surprised it hasn't pooled up in a low spot of the yard yet. That's above the melting temp of.....everything :bug:
    Stinny and papadave like this.
  19. Mag Craft
    I run my Osburn no higher then 450, that is the max recommended by Osburn.
    I have good wood and no creosote problems.
  20. bert the turtle
    bert the turtle
    I hit about 700 fairly often, tend to run lower than that.
    ansehnlich1 and papadave like this.
