10mm 044
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, May 17, 2015.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    I have been breaking in the 10mm 044 for the last few months and enjoying the heck out of it. Compression is up over 170. I put an outerwears prefilter on the HD filter and finally got a DP muffler cover, they have been hard to find here recently.
    So I retuned and sank it in an old white oak and :D. Here is a little video. Also running a square filed chain.
    RJames, $ooline, Shawn Curry and 10 others like this.
  2. Chvymn99
    That's bad a$$.... Great video!
    foragefarmer and XXL like this.
  3. NewToStihl
    NewToStihl
    Central Indiana
    BOOM!!! Very nice. Other than the DP cover and filter upgrade is it stock/original?
    foragefarmer likes this.
  4. rookie1
    rookie1
    Nice
  5. NH_Wood
    NH_Wood
    She's moving - sounds real good - nice saw!! Cheers!
    Deacon and foragefarmer like this.
  6. Jon1270
    Jon1270
    Pittsburgh, PA
    Just on Friday I cut up a big dead red elm trunk with mine, burying the nose of a 28" bar with full skip, and it did well. Unless I get heavily into milling, I don't see myself needing a bigger saw.
    splitoak and foragefarmer like this.
  7. DexterDay
    Great running saw!!
  8. Hinerman
    Hinerman
    NE Oklahoma
    Hammer down...
    concretegrazer and foragefarmer like this.
  9. foragefarmer
    foragefarmer
    Central, Virginia
    Thinner base gasket and new piston. The cylinder is a stock KS. I also ground the muffler gasket and muffler to match the exhaust opening.
    MasterMech, Chvymn99, rookie1 and 3 others like this.
  10. mdavlee
    mdavlee
    Those are nice running stock saws.
    foragefarmer, Chvymn99 and rookie1 like this.
  11. foragefarmer
    foragefarmer
    Central, Virginia
    Then add in a few tweaks and a square filed chain and they really wake up. Adding the DP cover changed the tune by 800 rpm.
  12. Jon1270
    Jon1270
    Pittsburgh, PA
    Exactly what I did too, but I built it before word got out about the affordability of OEM pistons so mine's a Meteor. I haven't picked up a DP cover, though, largely out of concern about how loud it might be. In fact the muffler I got for it has the smaller outlet that was stock on 12mm saws. I could probably stand to open it up to match the early 044 outlets, at least.
    rookie1 likes this.
  13. rookie1
    rookie1
    I would do that for sure. I opened one up for a tree cutter here in the city and he couldn't believe the difference.
    I just posted this thread. http://firewoodhoardersclub.com/forums/threads/open-up-ms440-muffler-outlet.12410/
    DexterDay and Jon1270 like this.
  14. foragefarmer
    foragefarmer
    Central, Virginia
    I have an early 12mm and the muffler outlet on it and the 10mm are the same.
  15. mdavlee
    mdavlee
    That doesn't hurt a bit.
  16. Jon1270
    Jon1270
    Pittsburgh, PA
    Ah, maybe I misunderstood the transition point. I've only every handled two 044's -- the one I sold to rjames, which was an early model with a red switch shaft, and the one I rebuilt and kept, which didn't come with a muffler at all. The used OEM muffler I got for it had a substantially smaller outlet.
    RJames likes this.
  17. foragefarmer
    foragefarmer
    Central, Virginia
    The 12mm 044 I have the SN starts 132xxx and had the diagonal fin Mahle cylinder on it when I got it. It was toast. I have had a 440 with the small opening so I know what you mean. I don't know when they shrank it down either. Maybe when they went to the straight fin design?
  18. Jon1270
    Jon1270
    Pittsburgh, PA
    Maybe. AFAIK the switch to right-angle fins coincided pretty closely with the switch to 12mm wrist pins, but not exactly.
  19. RJames
    RJames
    Unfortunately, I don't own that saw anymore, but it is in very good hands. I have regretted that decision since and I'm on the lookout for it's replacement. It was a good one for sure.
    Jon1270 likes this.
  20. Jon1270
    Jon1270
    Pittsburgh, PA
    Now I'm curious. What triggered your momentary lapse in judgement?
